Piousservant Posted January 14, 2013 Share Posted January 14, 2013 I’ve grudgingly come to the conclusion that my Ravenwing will need some air support in the form of a Nephilim Jetfighter but I’m not a big fan of the model (though it is easily the least worst marine aircraft GW have released so far). I do like, however, the FW Voss pattern Lightning. Which is also conveniently very similarly armed to the Nephilim, just needing the Hvy Bolters to be added, though I’ve no idea how it compares in size (but I’d think it must be similar). Do you think it would be a reasonable “counts as” if I used the Voss Lightning instead of the stock model? Link to comment Share on other sites More sharing options...
Harleqvin Posted January 14, 2013 Share Posted January 14, 2013 I think a couple of inches wingspan longer and the back tail section is about an inch or so wider on the Voss. Fuelsilage is about the same length it looks from the pictures. Just my gathering of the pictures. If at worse case scenario you get the voss and it's waaaay bigger, you now have a nice IG flyer. :lol: Link to comment Share on other sites More sharing options...
Bryan Blaire Posted January 14, 2013 Share Posted January 14, 2013 E-mail ForgeWorld and ask them about the dimensions? I would be okay with it in a game. Model-wise, I'm wondering how to attach the heavy bolters. A two three-barrel rotary cannons in cowlings on either side of the cockpit set forward might look cool. Link to comment Share on other sites More sharing options...
Piousservant Posted January 14, 2013 Author Share Posted January 14, 2013 If at worse case scenario you get the voss and it's waaaay bigger, you now have a nice IG flyer. Great!! E-mail ForgeWorld and ask them about the dimensions? I would be okay with it in a game. Model-wise, I'm wondering how to attach the heavy bolters. A two three-barrel rotary cannons in cowlings on either side of the cockpit set forward might look cool. Thanks, I will do and see what they say (though I've no idea what the actual Nephilim dimensions are...!). Yeah I'm not 100% sure how to add them on yet, but I figure there is enough room at the front to mount them somewhere. I was kinda thinking the heavy bolters from the Master of the Ravenwings land speeder might fit okay up forward in front of the cockpit but I'm not sure. Link to comment Share on other sites More sharing options...
Bryan Blaire Posted January 15, 2013 Share Posted January 15, 2013 I'll try and get you the Nephilim dimensions tomorrow unless someone can get them for you before then. Link to comment Share on other sites More sharing options...
