hrafnkel Posted January 16, 2013 Share Posted January 16, 2013 Thewarstore's missile launchers are really expensive, about 15 dollars in the currency that I use. gonna just use lascannons and cut off the barrel snout and make it counts-as missile launchers. That's allowed right? Unless any other brothers here know where I can get cheaper ones. Btw anyone know what happened to warandfantasygames.com? Link to comment https://bolterandchainsword.com/topic/269719-missile-launchers/ Share on other sites More sharing options...
skeletoro Posted January 16, 2013 Share Posted January 16, 2013 Do you have a bunch of rhinos? You can convert hunter killer missiles to look pretty convincing. It's a tad fiddly, but not TOO bad. http://www.bolterandchainsword.com/index.php?showtopic=241037 Link to comment https://bolterandchainsword.com/topic/269719-missile-launchers/#findComment-3285185 Share on other sites More sharing options...
Squark Posted January 16, 2013 Share Posted January 16, 2013 I don't think a lascannon that had lost the barrel would look sufficiently missile launcher-ish.You could probably get away with it, but I don't reccomend it. The hunter-killer trick is much better, and you can usually get a few from the bits boxes of your fellow players if you ask nicely if you're not doing mech. Link to comment https://bolterandchainsword.com/topic/269719-missile-launchers/#findComment-3285512 Share on other sites More sharing options...
Russ Brother 92 Posted January 16, 2013 Share Posted January 16, 2013 I think if you found some cheaper old-school lascannons and missile launchers - the RT/2nd Ed ones it would be better as they're shoulder-mounted. Link to comment https://bolterandchainsword.com/topic/269719-missile-launchers/#findComment-3285688 Share on other sites More sharing options...
Wicks Posted January 16, 2013 Share Posted January 16, 2013 I say keep the lascannons. Wolves have always had trouble with range firepower.Put them in a longfangs with maybe some plasma cannons and BAM! killer unit and the new codex for dark angels you are going to see a bunch of deathwing terminators. My gaming experience is limited so forgive me if I stepped on other peoples toes but that is what i would do. Link to comment https://bolterandchainsword.com/topic/269719-missile-launchers/#findComment-3286373 Share on other sites More sharing options...
hrafnkel Posted January 17, 2013 Author Share Posted January 17, 2013 I have had a problem bringing mixed loadouts in my LFs; I just have that aversion to mixing and matching. I've tried it at least once, but I can't remember the result, so I suppose it wasn't good enough to warrant me to continue. I have enough hunter killer missiles for an entire squad of 5 MLs, but conversely I was enough of an idiot to want 5 LCs in an entire squad, hence my conundrum. Thanks for the replies yo. Link to comment https://bolterandchainsword.com/topic/269719-missile-launchers/#findComment-3286566 Share on other sites More sharing options...
Squark Posted January 17, 2013 Share Posted January 17, 2013 Assuming I've interpreted your post right, yeah, 5 Lascannons is just too expensive. I wouldn't go above 2-3 in a squad- Use missile Launchers to fill out the squad. Plasma cannons are similar- I don't reccomend mixing and matching the two, since you end up being too expensive and Plasmacannons don't really do well shooting at things Lascannons want to shoot at anyway. Link to comment https://bolterandchainsword.com/topic/269719-missile-launchers/#findComment-3286598 Share on other sites More sharing options...
Max_Dammit Posted January 17, 2013 Share Posted January 17, 2013 try and get some of the old ones, there not as expensive, and even Forgeworld is cheaper than the normal ones on bits sites Link to comment https://bolterandchainsword.com/topic/269719-missile-launchers/#findComment-3286677 Share on other sites More sharing options...
skeletoro Posted January 17, 2013 Share Posted January 17, 2013 Yep, what is it, 11 pounds for 2 oldskool resin ones at forgeworld? Honestly, that's how I'll be doing it if I make a third squad of longfangs. I probably won't though... long fangs are great but yeah, they're kinda boring! Link to comment https://bolterandchainsword.com/topic/269719-missile-launchers/#findComment-3286707 Share on other sites More sharing options...
