Space Wolves (13th Company) 1500pts HELP?
St. Veratis
Hey all, a bit new to this forum (Some of ya'll will notice I've done some Black Templar stuff; but my Warhammer ADD has kicked in)
I want the list to be fun, slightly competitive n stickin' to the fluff n this is what I came up with for a 1500 point list:
Wold Lord
- Dual Wolf Claws
- Thunderwolf Mount
- 2 Fenrisian Wolves
- Belt of Russ
- Saga of the Warrior Born
- Saga of the Wolfkin
15 Fenrisian Wolves
Wolf Priest
- Saga of the Hunter
- Meltabombs
10 Grey Hunters (Slayers)
- Flamer
- Meltagun
- Power Axe
- Mark of the Wulfen
Rune Priest
- Runemaster
- Chooser of the Slain
- Living Lightning
- Storm Caller/Tempests Wrath
- 2 Plasma Guns
- Power Axe
10 Wolf Scouts
- 3 Meltabombs
- Meltagun
- Power Weapon (Undecided)
6 Long Fangs
- 3 Missile Launchers
- 2 Lascannons
Lone Wolf
- Meltabombs
STRATEGY (i.e Wishful Thinking): The hope is to get the Wolf Lord into combat, it's what he's born to do. A lot of points sunk into this model to make him survivable n lethal n Close Combat; the Wolves are more of a meatshield than anythin'.
The Runepriest n his Squad will either sit back on an object, or follow the Wolf Lord n give his squad the 5+ Cover n also provide fire support.
The Long Fangs do what they do best. Sit back n shoot at everythin'. Simple enough.
The Wolf Scouts are my tank bustin' unit as well as situated for anti-infantry.
Same with the Wolf Priest n his squad. Thanks the the Saga Hunter rule he n his unit can outflank n will focus more on anti-infantry n assassination.
The idea is like a massive pincer (Or wolf jaw if you prefer) 2 units close in from the front while 2 come in from the back. Space wolves are extremely versatile.
I want to stick to the fluff though, so this means an infantry based list. No tanks, no walkers n no Terminators.
Any thoughts?
A few notes:
Your wolf lord can only have 1 saga sadly.
I would take 1 PF and 1 WC over 2xWC - gives you a lot more flexabillity
Your Lone wolf is going to die pretty quick - normally he is put to best use in a Terminator Armor and with a Storm Shield.
Wolf Scouts are not worth it in 6th edition - since they can't charge after outflank. Better to exchange them for more long fangs.
I know this goes a bit against the fluff you are looking for - but I would try get red of the scouts, or make the squad smaller, and outfit them with a lot of plasma gun + pistols: which can net you 4 plasma shots.
Double-check the Scout entry- believe you have to upgrade all to get Meltabombs, if you want any. You can't just take 3 for those 10 guys.
Someone else already mentioned 1 Saga per customer,
Valerian
I'd suggest you drop Saga of the Warrior Born (he still gets a ton of S5 attacks) - and don't take the Power Weapon on your Scouts, yes you do have to take Melta Bombs for ALL the pack, would be nice if it was individual but ahwell :(
Otherwise a decent list - though I'd take two smaller Scout packs...
