Heads for MK VIII torsos
I've found that bare heads generally fit the plastic Mk.VIII 'collar' as do many of the older metal heads from Chapter/Squad specific kits.
Having said that, pretty much anything except the MkVI will fit easily enough if you strategically shave the back of the helmet down. Alternatively add a little GS to the base of the neck as the extra clearance often makes the fit easier too.
