Painting oil
I need advice on painting oil. It's no really for vehicles but instead between armour joints and spilling from mouths.
I know there was a good tutorial in a white dwarf a good wee while back, it was how to paint an ork stompa so must have coincided with their release.
https://bolterandchainsword.com/topic/270915-painting-oil/
A brown-black works well. As with all weathering, 'less is more' should be your mantra. It's very easy to add a bit more, and it's very easy to overdo it. Start by using a fine tip brush to add just a streak or two or pin wash into recesses. Build it up slowly.
https://bolterandchainsword.com/topic/270915-painting-oil/#findComment-3299786
If you seal the model with varnish you can thin the oil paint with mineral spirits and then use it like a wash. If you overdo it you can simply use pure mineral spirits to do a sort of reverse dry brush on it.  Awesomepaintjob's youtube channel has some examples of this. It works really well for painting Deathwing.
https://bolterandchainsword.com/topic/270915-painting-oil/#findComment-3299977
