Dirus Posted February 9, 2013 Share Posted February 9, 2013 Hi there.Pardon me if there is a misunderstanding, I'll try and explain it as best as i can. Feel free to move this isn't the right place to post this too.I'm planning to convert some PAGKs painted up in the same color scheme as my DIY chapter but still take them as Grey Knight allies. Is it okay for me to do so? Is it frowned upon?I'm not using a proxy or anything, they'll still have halberds, falchions, etc. just without the Grey Knight iconography. Link to comment https://bolterandchainsword.com/topic/271001-using-counts-as-models/ Share on other sites More sharing options...
GodEmperorOfMankind Posted February 9, 2013 Share Posted February 9, 2013 Go for it, they're your models! if you're using the actual models just in a different colour scheme then I ca't see why anyone would complain Link to comment https://bolterandchainsword.com/topic/271001-using-counts-as-models/#findComment-3300880 Share on other sites More sharing options...
Dirus Posted February 10, 2013 Author Share Posted February 10, 2013 Alright thanks! Link to comment https://bolterandchainsword.com/topic/271001-using-counts-as-models/#findComment-3301107 Share on other sites More sharing options...
lothlorienmoon Posted February 10, 2013 Share Posted February 10, 2013 Proxy models/counts-as are generally "Hey, this may look like a necron, but it's actually my chaplin." If you can clearly tell that the model is a grey knight, who just happens to be bright pink, well it's still a grey knight. Otherwise DIY chapters would all be unusable because they aren't painted like the models on the box. Link to comment https://bolterandchainsword.com/topic/271001-using-counts-as-models/#findComment-3301128 Share on other sites More sharing options...
Dirus Posted February 10, 2013 Author Share Posted February 10, 2013 That's very true.In my case anyways, I'm taking Grey Knights as allies. They're just painted with the same scheme as my DIY chapter. Link to comment https://bolterandchainsword.com/topic/271001-using-counts-as-models/#findComment-3301146 Share on other sites More sharing options...
GodEmperorOfMankind Posted February 10, 2013 Share Posted February 10, 2013 I would say it's always worth mentioning which units are allies to your opponent beforehand just as a matter of courtesy as they may not notice the difference in models and it could be confusing when you suddenly start using GK rules on your SM units. Link to comment https://bolterandchainsword.com/topic/271001-using-counts-as-models/#findComment-3301201 Share on other sites More sharing options...
Dirus Posted February 10, 2013 Author Share Posted February 10, 2013 Of course, especially since i plan on painting my Grey Knight allies as my DIY chapter.It'd cause a lot of confusion if i don't specify beforehand. Link to comment https://bolterandchainsword.com/topic/271001-using-counts-as-models/#findComment-3301229 Share on other sites More sharing options...
GhostLegion Posted February 10, 2013 Share Posted February 10, 2013 while in full agreement with the above that youre fine doing this, as an oppoent I wouldnt mind additional indicators to identify a different force. not so much that i would require them...just a desire on my part. really ive seen this as simple as a different color ring on the base of the model to signify a secondary force...or something as complex as different paint scheming on the shoulders while maintaining the uniform scheme for the force itself. again, this is more a preference. in all honesty, you should have no problem with any opponent here as youre using grey knight models for grey knight allies...its not like youre using goblins/gretch to be space marines here. Link to comment https://bolterandchainsword.com/topic/271001-using-counts-as-models/#findComment-3301250 Share on other sites More sharing options...
Dirus Posted February 10, 2013 Author Share Posted February 10, 2013 Thanks for the great advice.I'll be sure to put a marker of sorts to differentiate which ones are the GK and which are the SM. I'll probably make the GKs the 1st company veterans so they'll get a different paint scheme from the regulars. Link to comment https://bolterandchainsword.com/topic/271001-using-counts-as-models/#findComment-3301285 Share on other sites More sharing options...
Disruptor_fe404 Posted February 11, 2013 Share Posted February 11, 2013 Proxy models/counts-as are generally "Hey, this may look like a necron, but it's actually my chaplin." Just a nitpick, the quoted is proxying and is most definitely not counts-as. There is a distinction between the two. The more you know! Link to comment https://bolterandchainsword.com/topic/271001-using-counts-as-models/#findComment-3301842 Share on other sites More sharing options...
Xenith Posted February 14, 2013 Share Posted February 14, 2013 The more you know! Indeed. And in this particular case, having Grey Knight models used as Grey Knight allies is neither a proxy, or a counts as. Link to comment https://bolterandchainsword.com/topic/271001-using-counts-as-models/#findComment-3304840 Share on other sites More sharing options...
ASSASSINAWOKEN Posted February 14, 2013 Share Posted February 14, 2013 I have continuously used an older Emperor's Champion model as a librarian. No one will care and most likely will want to just get a game started. Just make sure you let your opponent know before hand. Link to comment https://bolterandchainsword.com/topic/271001-using-counts-as-models/#findComment-3305065 Share on other sites More sharing options...
