IndigoJack Posted February 20, 2013 Share Posted February 20, 2013 Does hammerhand affect krak grenades? I can't seem to find anything saying otherwise. It seems so obvious, but something I've never seen mentioned before. Thoughts? Link to comment https://bolterandchainsword.com/topic/271598-krak-grenades-hammerhand/ Share on other sites More sharing options...
GOFADK Posted February 20, 2013 Share Posted February 20, 2013 The short answar is NO.Hammerhand gives you +1S in CC and krak grenades gives you a set S8 Attack, instead of using your normal attack and S. Link to comment https://bolterandchainsword.com/topic/271598-krak-grenades-hammerhand/#findComment-3309629 Share on other sites More sharing options...
SamuraiOrk Posted February 20, 2013 Share Posted February 20, 2013 Hammerhand only effects the users strength and isn't transferred to a weapon's set strength (ie. grenades,melta bombs, etc). Link to comment https://bolterandchainsword.com/topic/271598-krak-grenades-hammerhand/#findComment-3309630 Share on other sites More sharing options...
IndigoJack Posted February 20, 2013 Author Share Posted February 20, 2013 Aha! I knew it was too good to be true. Thanks for setting me straight! Link to comment https://bolterandchainsword.com/topic/271598-krak-grenades-hammerhand/#findComment-3309652 Share on other sites More sharing options...
Seahawk Posted February 20, 2013 Share Posted February 20, 2013 The short answar is NO. Hammerhand gives you +1S in CC and krak grenades gives you a set S8 Attack, instead of using your normal attack and S. Incorrect. Krak grenades are Strength 6. Simply follow the rules on page 2 or 3 I think. Multiple/Divide, then Add/Subtract, then Set Numbers. In this case it's: 4, then +1 for 5, then just 6. Link to comment https://bolterandchainsword.com/topic/271598-krak-grenades-hammerhand/#findComment-3309836 Share on other sites More sharing options...
thade Posted February 20, 2013 Share Posted February 20, 2013 Possibly the confusion comes from the second step up, melta bombs (which are S8). In any event, Seahawk et. al. have already set the record straight. Link to comment https://bolterandchainsword.com/topic/271598-krak-grenades-hammerhand/#findComment-3310091 Share on other sites More sharing options...
GOFADK Posted February 21, 2013 Share Posted February 21, 2013 The short answar is NO. Hammerhand gives you +1S in CC and krak grenades gives you a set S8 Attack, instead of using your normal attack and S. Incorrect. Krak grenades are Strength 6. Yir... That was a typing error :) Link to comment https://bolterandchainsword.com/topic/271598-krak-grenades-hammerhand/#findComment-3310448 Share on other sites More sharing options...
