Cub question -
montegue
Greetings,
I'm a bit confused. Our Codex says our transport capacity in a Drop Pod is ten, but I'm told it's 12 for Space Marines. I commonly see army lists that seem to stick models in a drop pod under the umbrella of a 12 model limit, but I can't actually find out the true answer to the question I have.
Do we need to take the smaller capacity drop pod, or do we have access to the Space Marine 12-model count drop pod. Or, did I just blatantly miss something in an FAQ someplace and am I just wasting folks time?
https://bolterandchainsword.com/topic/271623-cub-question/
We only get 10 Wolves per pod, need to save room for the mead.
C:SM was one of the first to come out in 5th edition and those armies do have 12 spots in a droppod.  Considering that the actual drop pod model only has 10 harnesses, I would hazard a guess that the next C:SM will be dropped down to 10 spots as well.
Cheers!
https://bolterandchainsword.com/topic/271623-cub-question/#findComment-3309929
yes that is one of the perks for normal SM codex units...
12 to a drop pod
12 to a land raider
16 to the crusader
400 to the Battle Barge...
DAMN YOU SMURFS AND YOUR ABILITY TO LOGICALLY ALLOW MORE MEN TO USE A VEHICLE THEN OTHER CHAPTERS OF THE ASTARTES...
https://bolterandchainsword.com/topic/271623-cub-question/#findComment-3309938
Cheers!
I would hazard to guess that they like to sit on each others laps on the way down.. hahaha
That is a good observation though. Ten harnesses in the drop pod.
I wish we could fit 12 in ours.  10 Hunters and a TDAWG.  Yikes!
https://bolterandchainsword.com/topic/271623-cub-question/#findComment-3309958
