Master Matthius Posted February 21, 2013 Share Posted February 21, 2013 So I forgot to make my WIP posts so I'll do this right now. I still need to work on my Librarian until I'm done so I'll be able to make my minimum WIP posts. Whoops... forgot. So here is part of my WIP for the LPC This is basically what I started with: Squad of Terminators from the DV set and a couple Rhinos on Sprues When I took this I had already assembled and primed and washed the Termi's obviously. Started building up the bone armor color: Kept working on the bone color until was finally layered up enough and leaving the wash in the recesses for lining. The picture above shows the termi's about 75% done, really that's left are the chest eagles and other detail work. Here are a couple final result pics of the DW Termis Link to comment https://bolterandchainsword.com/topic/271690-lpc-wip-for-master-matthius/ Share on other sites More sharing options...
Master Matthius Posted February 21, 2013 Author Share Posted February 21, 2013 And the Rhino build I didn't do much picture taking with as it's pretty simplistic build and such. Here are the pics of that Onto the Librarian this weekend and I should be able to call this done. Link to comment https://bolterandchainsword.com/topic/271690-lpc-wip-for-master-matthius/#findComment-3311040 Share on other sites More sharing options...
Master Matthius Posted March 31, 2013 Author Share Posted March 31, 2013 My final entry for this WIP. Here is my Librarian. Start to finish. Right off the sprue Primed Base coats Shading started Shading and highlighting on the back First set of shades and highlights on the other pieces Second set of shades and highlights on other pieces Close to completion Completed Another angle Last shot Link to comment https://bolterandchainsword.com/topic/271690-lpc-wip-for-master-matthius/#findComment-3339443 Share on other sites More sharing options...
