Shiodome Posted February 22, 2013 Share Posted February 22, 2013 Title says it all really, does anyone know of a paint already formulated for airbrushes that closely resembles caliban green (a very slight variance would be fine). I know there's things like a vallejo/GW comparison chart floating about, but i'm told it's not especially reliable and doesn't cover the vallejo air range anyway. Thanks in advance for any help. :) Link to comment https://bolterandchainsword.com/topic/271722-airbrush-paint-equivalent-for-caliban-green/ Share on other sites More sharing options...
MedPig Posted February 22, 2013 Share Posted February 22, 2013 Depends. If you want a CLOSE match, try Vallejo "Black-Green", it's a WW2 German color in the model paint line, I think. Testor's Model Master paints have an oil-based enamel version of it, too. I use it for a LOT of things, it's a very cool color. Hope that helps. Link to comment https://bolterandchainsword.com/topic/271722-airbrush-paint-equivalent-for-caliban-green/#findComment-3311599 Share on other sites More sharing options...
Shiodome Posted February 22, 2013 Author Share Posted February 22, 2013 thanks, will give that a try and report back o7 Link to comment https://bolterandchainsword.com/topic/271722-airbrush-paint-equivalent-for-caliban-green/#findComment-3311903 Share on other sites More sharing options...
DarkMark Posted February 28, 2013 Share Posted February 28, 2013 Just use thinner with the Caliban green and you won't need a replacement! Link to comment https://bolterandchainsword.com/topic/271722-airbrush-paint-equivalent-for-caliban-green/#findComment-3317042 Share on other sites More sharing options...
Captain_Quirk Posted March 2, 2013 Share Posted March 2, 2013 To ask a supplementary question to the OP's (and apologies for the hijack!) - if I were to use thinner on my Caliban green can anyone give advice on best ways of getting the paint from the pot to the jar without making a godawful mess? I've tried a dropper which didn't really work. How do you measure it all out? It also seems like I'd have to use rather a large amount of Caliban green to do even a couple of models? Link to comment https://bolterandchainsword.com/topic/271722-airbrush-paint-equivalent-for-caliban-green/#findComment-3318613 Share on other sites More sharing options...
Lorenzen Posted March 2, 2013 Share Posted March 2, 2013 if you thin your paints properly it shouldnt take much to coat quite a lot of models well.. why didnt the dropper work? was the paint too thick in the pot already? if so why not add some thinner to it... i mean if you're going to be airbrushing with it anyway.. essentially the best answer is "caliban green with thinner added" Link to comment https://bolterandchainsword.com/topic/271722-airbrush-paint-equivalent-for-caliban-green/#findComment-3318624 Share on other sites More sharing options...
Captain_Quirk Posted March 2, 2013 Share Posted March 2, 2013 Thanks Lorenzen. The dropper just caused the paint to stick to the inside of the dropper -_- however I think maybe this time I will try sucking up the paint and then an equal amount of thinner. Hopefully they'll mix inside the dropper and give me the results that I want. I am really keen to use my airbrush to base coat my DA and CSM because doing it with a regular brush takes forever. Link to comment https://bolterandchainsword.com/topic/271722-airbrush-paint-equivalent-for-caliban-green/#findComment-3318638 Share on other sites More sharing options...
Lorenzen Posted March 2, 2013 Share Posted March 2, 2013 if you're still having trouble getting the mix right another option (cheap and lame as it may seem) is to keep the tops of coke bottles etc and use them to mix in (after rinsing them out!) they provide a suitable mini mixing pot for things like this.. then once you're ready suck it up via dropper and transfer it to the airbrush. Link to comment https://bolterandchainsword.com/topic/271722-airbrush-paint-equivalent-for-caliban-green/#findComment-3318647 Share on other sites More sharing options...
