Cmdr Shepard Posted February 22, 2013 Share Posted February 22, 2013 Greetings fellow hobbyists, I need your help. I decided to start to paint some of my Son of Horus models and I'm encountering difficulties in recreating their green. For the infantry models I used the method suggested in Oct WD (the tutorial had the wrong wash but I corrected according to what I read here on B&C) I painted a layer of Mechanicus Grey, draybrushed Necron Compound and Coelia wash. I tested it on a CSM mini and it looked nice. Perhaps a little darker than it appears on the pages of Betrayal but it still have that "metallic look" SM armours show in FW books. The issue took place when I tried to use the same technique on the plain surfaces of a vehicle (I knew it wouldn't have worked in the same way) The color lack "visual cohesion", namely some areas are barely green while others (where wash accumulated) are far more darker. If I try to apply other washes I just increase the number of different shade spots. I'm quite familiar with such events but when you use washes to darken an already existing color the different shades on the vehicle surfaces are quite useful but in such case the wash is ment to determine the actual color so I end with "maculated" vehicle. It looks like a green Dalmatian dog, if you know what I mean ;) Do you have any suggestion in how to recreate SoH green without using the extensive mixture procedure found on FW site? Thank you for your help. Link to comment https://bolterandchainsword.com/topic/271729-help-with-sons-of-horus-green-especially-for-vehicles/ Share on other sites More sharing options...
Marshal Traben Posted February 22, 2013 Share Posted February 22, 2013 What washes did you use on the vehicle? Link to comment https://bolterandchainsword.com/topic/271729-help-with-sons-of-horus-green-especially-for-vehicles/#findComment-3311803 Share on other sites More sharing options...
Cmdr Shepard Posted February 23, 2013 Author Share Posted February 23, 2013 What washes did you use on the vehicle? Coelia greenshade on a "test area" of a vindicator . It was just to see if it could work. I knew the chances of success would be very low.... Link to comment https://bolterandchainsword.com/topic/271729-help-with-sons-of-horus-green-especially-for-vehicles/#findComment-3312516 Share on other sites More sharing options...
Marshal Traben Posted February 23, 2013 Share Posted February 23, 2013 I think you could ask to sheep about it. His SoH vehicles appear to be same shade as his infantry. http://www.bolterandchainsword.com/topic/254518-sons-of-horus-once-more-into-the-breach/page-4 Or anyone with more extensive knowledge, of how to paint marine vehicles the same color as the infantry. Link to comment https://bolterandchainsword.com/topic/271729-help-with-sons-of-horus-green-especially-for-vehicles/#findComment-3312643 Share on other sites More sharing options...
Cmdr Shepard Posted February 23, 2013 Author Share Posted February 23, 2013 I think you could ask to sheep about it. His SoH vehicles appear to be same shade as his infantry. http://www.bolterandchainsword.com/topic/254518-sons-of-horus-once-more-into-the-breach/page-4 Or anyone with more extensive knowledge, of how to paint marine vehicles the same color as the infantry. Thanks for the link. I'll try to find there the info I need. I suspect a mixture of colors could be the only choice. After all SoH green is a peculiar shade of that color.... Link to comment https://bolterandchainsword.com/topic/271729-help-with-sons-of-horus-green-especially-for-vehicles/#findComment-3312685 Share on other sites More sharing options...
Marshal Traben Posted February 23, 2013 Share Posted February 23, 2013 I'm always happy to help, though i'm not sure if that link has the info you're looking for. Link to comment https://bolterandchainsword.com/topic/271729-help-with-sons-of-horus-green-especially-for-vehicles/#findComment-3312695 Share on other sites More sharing options...
S.k.i.t.t.l.e Posted February 23, 2013 Share Posted February 23, 2013 Over a larger area such as a vehicle side or something, I think that the technique would be more akin to glazing than washing. The main difference being that glazing is a tint over he whole area and washing is usually just to darken recesses etc. The main difference in applying these techniques I would say, is the amount of liquid on your brush, if when you make a brush stroke on an area and you are left with a greater amount of liquid than the start of the stroke you have too much on your brush for glazing. For glazing it should be a very thin, fairly uniform amount of colour left at the start and the end of a brush stroke. Also, if you hit it just right, the pigment left at the start of the brush stroke should just be starting to dry as you finish your stroke. Link to comment https://bolterandchainsword.com/topic/271729-help-with-sons-of-horus-green-especially-for-vehicles/#findComment-3312833 Share on other sites More sharing options...
Cmdr Shepard Posted February 24, 2013 Author Share Posted February 24, 2013 Over a larger area such as a vehicle side or something, I think that the technique would be more akin to glazing than washing. The main difference being that glazing is a tint over he whole area and washing is usually just to darken recesses etc. The main difference in applying these techniques I would say, is the amount of liquid on your brush, if when you make a brush stroke on an area and you are left with a greater amount of liquid than the start of the stroke you have too much on your brush for glazing. For glazing it should be a very thin, fairly uniform amount of colour left at the start and the end of a brush stroke. Also, if you hit it just right, the pigment left at the start of the brush stroke should just be starting to dry as you finish your stroke. That's a very good suggestion. Thanks . I used that technique in the past (on infantry models, though) with blue wash over metallic color. However I suspect a thin layer of coelia will create a light green effect quite different than SoH ones but undoubtly better than the "wash". I'm always happy to help, though i'm not sure if that link has the info you're looking for. It's a good starting point, though ;) The problem is many of SoH greens I found here on B&C use non GW colors and it's quite difficult to find them in my region. That's one of the reasons I always use GW colors. I have no difficulty in finding them ;) Link to comment https://bolterandchainsword.com/topic/271729-help-with-sons-of-horus-green-especially-for-vehicles/#findComment-3313064 Share on other sites More sharing options...
Marshal Traben Posted February 24, 2013 Share Posted February 24, 2013 Funny thing is that where i live, i can easily find both GW and non GW paints. Link to comment https://bolterandchainsword.com/topic/271729-help-with-sons-of-horus-green-especially-for-vehicles/#findComment-3313079 Share on other sites More sharing options...
Cmdr Shepard Posted February 24, 2013 Author Share Posted February 24, 2013 Funny thing is that where i live, i can easily find both GW and non GW paints. You are luckier than me, then ;) Link to comment https://bolterandchainsword.com/topic/271729-help-with-sons-of-horus-green-especially-for-vehicles/#findComment-3313118 Share on other sites More sharing options...
Marshal Traben Posted February 24, 2013 Share Posted February 24, 2013 I guess i'm lucky that i live in the Espoo county next to Helsinki, Finlands capital. And what paints i don't find from the stores, i buy from the internet. Link to comment https://bolterandchainsword.com/topic/271729-help-with-sons-of-horus-green-especially-for-vehicles/#findComment-3313122 Share on other sites More sharing options...
Cmdr Shepard Posted February 24, 2013 Author Share Posted February 24, 2013 I guess i'm lucky that i live in the Espoo county next to Helsinki, Finlands capital. And what paints i don't find from the stores, i buy from the internet. I prefer to not buy paints from the Internet due to shipping charges ;). I would have access to all the paints available worldwide via internet but a single paint does not justify shipping charges. I also tend to not use non trackable shipping methods because every time I did I got very long delays in delivery. Link to comment https://bolterandchainsword.com/topic/271729-help-with-sons-of-horus-green-especially-for-vehicles/#findComment-3313126 Share on other sites More sharing options...
Marshal Traben Posted February 24, 2013 Share Posted February 24, 2013 I've ordered some Vallejo paints from amazon, they are usually those that i don't find from the hobby stores. Link to comment https://bolterandchainsword.com/topic/271729-help-with-sons-of-horus-green-especially-for-vehicles/#findComment-3313356 Share on other sites More sharing options...
