Frost Axes
Marshall Bretton
Sorry to butt in folks but what about the idea of a frost axe and a frost sword (on a wolf lord)?  Then you could use the ap3 full initiative against normal marines, ap2 against the heavies, get the extra attack and that would look damn good (throw in a belt of russ aswell).  I know it's expensive but is it a good compromise?
Meatgrinder:
Yep, frost axes aren't good. I was talking about power axes. Power axes are very good.
In terms of wounds caused per point spent, vs guardsmen/marines/terminators:
TDAWG w power axe: .051/.030/.020
TDAWG w power fist: .039/.030/.020
+3 strength sounds like a lot but it's really +0 to +1, against infantry. You're rarely going to get any use out of >str 6.
EXCEPT against vehicles, extremely tough foes (e.g. monstrous creatures) and multi wound t4 foes. That's where power fists become worth it.
Meatgrinder:
It is also instant death vs anyone t4 or lower, and you have the versatility to kill bigger things, all for an extra 10 points, thats why you take it. Power axes can't take down vehicles or MCs, and vs characters youre likely to only get one hit at most (out of your two) past their invul, and you want it to count. Remember in TDA, you won't be getting the extra attack. You could give him meltabombs, but youre striking rear armour, which is likely AV10-12, for the extra points you might aswell take the fist.
Axes might be superior vs infantry, but you're just gimping yourself if you get stuck in a bad spot (which you will). Fists are the superior choice for all-comers lists.
