Transfers...
Micro Sol and set, yes. Also, this is optional but it does help, apply a gloss coat to the area that you're going to be applying the transfer. It actually helps it go on smoother and lessens any air bubbles. After its dried, apply another coat of gloss over it to seal it, then a flat coat to dull it.
https://bolterandchainsword.com/topic/271946-transfers/#findComment-3315726
as above, but I prefer to use 'Ardcoat (new Technical range) put it where the tranfer will go, apply transfer, another layer of 'Ardcoat. simple as that. as I understand, 'Ardcoat is Citadels answer to micro-set/sol. It really does work wonders. when I posted my first mini using it, a lot of people commented on the tranfer. no shiney effect or noticeable edge. etc. just make sure you do it before your matte sealer! here is a pic of what I mean.
http://i1093.photobucket.com/albums/i438/furioso-prime/darkangels001-2.jpg
https://bolterandchainsword.com/topic/271946-transfers/#findComment-3316205
After micro-setting the decal on the model, I put it in front of a hair dryer (low fan, high heat) for at least 2-3 minutes. Then I press my fingertip down onto the decal and slowly roll it back and forth. Then I brush on the micro-sol and let the model sit overnight.
https://bolterandchainsword.com/topic/271946-transfers/#findComment-3316536
That's interesting, I've heard much of the micro sol but I've never seen any for sale anywhere so alternatives are worth a shot (especially cheaper ones!). I'll give it a go next I'm putting some transfers on, it's not like anyone is short of transfer sheets to experiment on :P
https://bolterandchainsword.com/topic/271946-transfers/#findComment-3317549
