well done for realising, i was of course asking what you meant by "it" being "at other forums" did you mean that the leaked codex is on these forums or people have been randomly speculating on these forums or even matt ward is doing a live video explaining how hes making epidemius give every nurgle unit the flyer type.
https://bolterandchainsword.com/topic/271979-epidemius/#findComment-3315766
from german rumor translation thanks to oliver (via faeit212):
Epi only effects Daemons of Nurgle within 6" and tally works based on unsaved wounds caused by Daemons of Nurgle:
7+: +1 Strength
14+: +1 Toughness
21+: 2+ poison
28+: 4+ Feel No Pain
(so pretty much nerfed 2-3 steps beyond oblivion)
https://bolterandchainsword.com/topic/271979-epidemius/#findComment-3315882
I'm just going by rumors and speculation - all of which could be wrong.  I haven't seen the book.  That said, the rumors fit with the GW pendulum policy of new rules going out of their way to ruin anything that was previously good.  Sadly, it seems of late they've forgotten that they're also supposed to supercharge new things and things that peviously sucked, at least when it comes to chaos.  CSMs at least got the drake, the rumors have yet to supply any sort of mitigating factor for daemons.  So far it sounds pretty awful for them all round.  Like, hang up your models, don't buy the codex, and sit 40k out for a while.
I haven't been following the fantasy rumors, maybe you can cut your models of their round bases, glue them to some square bases, and you might be ok to go?
Or maybe the rumors will turn out to be so much hot air and pessimism.  I don't know, but I'm not especially hopeful at this point.
https://bolterandchainsword.com/topic/271979-epidemius/#findComment-3315924
http://www.lounge.belloflostsouls.net/showthread.php?27643-Daemons-Rumours&p=287134&viewfull=1#post287134
Right, a lot of stuff there (direct translation from the German codex that someone, somewhere has, apparently).
I'm happy, as it seems GW are releasing codexes quite often since the release of 6th, and also the power level seems to be... ok. Not quite to the same level as SW, GK and necrons, but they will get their new codex one day :D
I also didn't like Epidemius, too much of a 1 trick pony personally, even though a fully nurgled up force tallied up was great :D
https://bolterandchainsword.com/topic/271979-epidemius/#findComment-3316282
The rumors are already in the other Epidemius thread you started henry and they're in the various Codex Daemons rumor threads in the Malificorum and Ascendant forums.
Anyway my opinion is that as soon as it's time for GK and the like to get new Codex books the power level will have come around again and we'll be stuck with these.....
https://bolterandchainsword.com/topic/271979-epidemius/#findComment-3316303
the new tally isn't hardly worth bothering with, where as before it made nurgle armies viable of its own, and constituted the only major direct synergy between the allied codeces.
Now?  Now it's not worth bothering with.  If in exchange we get nurgle stuff that's good enough on its own to run without tally then that might be an acceptable trade, but I'm not especialy confident of that at the moment.  Either way, I'll regret the loss of direct synergy.  Daemons and CSMs are 'battle brothers', but they might as well not be, given that they're specifically excluded from taking advantage of any of the benefits that ally level has over allies of convenience.
Shame.
https://bolterandchainsword.com/topic/271979-epidemius/#findComment-3316892
Looks like Epi can be taken as a named "herald" instead of taking a whole HQ spot. Heralds are now 4 per 1 HQ spot (instead of 2 per 1 in previous codex), so you could take Epi and 3x Heralds of Nurgle for 1 HQ total.
Might be worth looking at.
You could always do this, except they used to take up 1/2 an HQ slot (ie 2 heralds = 1 HQ slot).  If they changed it to 4 heralds per HQ slot that would be interesting.
https://bolterandchainsword.com/topic/271979-epidemius/#findComment-3316919
I wouldn't go that far yet - I mean, who really hasn't pinned their models to the bases so they can just swap them over any time anyway? tongue.png
me. the round bases are slightly smaller. I've made my own square bases into which I "click" the round ones.
What did you use to do that? i've been thinking of doing the same thing but not sure how to do it.
Has anything been heard about Skulltaker, The Masque and The Blue Scribes?
https://bolterandchainsword.com/topic/271979-epidemius/#findComment-3317814
