WarriorFish Posted March 7, 2013 Share Posted March 7, 2013 I've just finalised a basing scheme (dirty xenos though, so they won't be appearing in these hallowed forums) that makes use of the water effect. I'm very pleased with how the bases turned out and the water effect looks really good with very little effort. So much so that I'm considering adding it to more armies, especially on larger bases (such as Stormtalon and Dreads). There are of course plenty of ideas such as bits and helmets etc to put in but one thing I thought would look really cool is blood in the water, especially if there was to be an enemy's head in it but I've no idea how to do this. Having the blood as a layer in the water effect makes sense, perhaps even laying multiple levels of it in thinner coats of the water effect but before I can try this out I need to get a good method of doing the blood. Blood is thicker than water so it would be a better idea not to thin the paint? So before I potentially waste what precious free time I have experimenting I thought I should come and ask for advice to help point me in the right direction. Has anyone done something similar or have any ideas? Thanks in advance for any help Link to comment https://bolterandchainsword.com/topic/272419-blood-in-the-water/ Share on other sites More sharing options...
georgeapg Posted March 8, 2013 Share Posted March 8, 2013 try TAMIYA X-27 Clear Red Link to comment https://bolterandchainsword.com/topic/272419-blood-in-the-water/#findComment-3323551 Share on other sites More sharing options...
The Sound of Machines Posted March 9, 2013 Share Posted March 9, 2013 Hey mate, I think I did something similar here: http://www.facebook.com/media/set/?set=a.222510891173768.53278.102661163158742&type=3 I used a really thin red ink/paint mix and an eyedropper to lay it in the botom before pouring the resin on top. The colour then lifted through the water. Some turned out better than others, less is more! :) Cheers, Luke Link to comment https://bolterandchainsword.com/topic/272419-blood-in-the-water/#findComment-3324206 Share on other sites More sharing options...
WarriorFish Posted March 9, 2013 Author Share Posted March 9, 2013 Thanks a lot for the replies brothers, I'll get some of the clear red and try and see what I can do. I'll post the results up here once I've done so but it will probably take a while. Link to comment https://bolterandchainsword.com/topic/272419-blood-in-the-water/#findComment-3324286 Share on other sites More sharing options...
