Daemon Questions
 Having read your infantile pathetic trolling at the dawn of the daemon codex, I assumed that dick (for lack of better uncensored words) would be a fairly fitting description for someone writing that kind of childish crap.
I'm done now.
There's only one person that's been infantile and childish here.  And it's not me.
I'm done now.
"Hahahahaha, this unit X is crap, because unit Y from my infamously
imbalanced Ward codex will easilly murder it, so your codex sucks since
it`s more balanced than mine"
Your level of self awareness  as to what is infantile and childish and not, is interesting to say the least.
I readilly confess that I was indeed childish to even react to your post. I shouldn`t have. I should just have not commented at all, remembering that this is after all the "Internet", notorious for all kind of trolling. There was however a very good reason why I accepted Cheextras post immediatly as "fair enough, good point that", while reacting very negativly to yours, even though you almost said the very same thing (with a certain notably difference in terms of linguistical intent). But yes, I should have ignored your jibe indeed and will indeed ignore any possible intelligent or nonsenical insinuations you may or may not make in the future.
...general common sense...
And that's the biggest issue. What is common sense? You'd say that it's common sense that those Horrors deserve to roll for their psychic abilities when they arrive from the Portalglyph. Others might call that an arbitrary adjustment of the rules, and that it makes more sense to use the rules as written. Common sense is, ironically, very subjective.
I think the biggest issue here is the management of expectations. I think it's a bit much to go into a game and expect that someone else will play by your house rules - because at its core, what you and your friends have made is a house rule. I might personally agree with it, but I would actually be kind of offended if you approached the issue with the mindset of "this is obviously THE common sense view, you're an idiot if you believe otherwise."
I second Furyou Miko's motion for free hugs. That is obviously the best common sense view :P
