alternative to micro-sol/set
The two pot varnishes from GW (Lahmian Medium and 'Ardcoat) work well enough. First put down a layer of 'Ardcoat. Then apply the decal as smoothly as possible, then to kill the shine and make the decal look like freehand, hit the whole area with a layer of Lahmian Medium. It's not perfect, but it does the job reasonably well.
The technique that Battle-Brother Ludovic poster will work decently, but transfers won't conform well to curved or irregular surfaces without a decal softener. You'll probably get a few small creases on curved areas like shoulder pads, but if you carefully remove as much of the excess film as possible, it should be entirely invisible at a tabletop distance.
Lahmian Medium does the same thing according to the GW website, although I haven't yet tried it myself:
http://www.games-workshop.com/gws/catalog/productDetail.jsp?prodId=prod1500290a
Lahmian Medium is not like Micro Set/Sol.
It's great for finishing off a transfer as it dulls down the shine, which I think is what is meant on the GW website, but it's not a decal softener.
  • 1 month later...
 Lahmian Medium, also anything that says medium, is used as a shader or ink. you take the color u want(red,black,etc) and mix it with the medium to make a instant inking. im using Americana varnish and mircro sol and they work very well together. iacentemque dominae ad mortem
  • 1 year later...
you can also use white vinegar mixed with water.  It does the same thing as the other decal sets and is way cheaper.
QFT. I couldn't find my MicroSol a while back and just used some thinned down white vinegar.
