Wraith776 Posted March 14, 2013 Share Posted March 14, 2013 Just wondering if I can still use a squads cover if hit by a plasma cannon. Because it has the blast template does the cover save still apply? Thanks for any help Link to comment Share on other sites More sharing options...
nurglez Posted March 14, 2013 Share Posted March 14, 2013 You still get cover saves vs blast weapons (unless specified). The tear drop template is the only weapon that will always ignore cover, although barrage weapons work out where the shot is coming from the small hole, so that will determine if a model gets a cover save (for example, if they is a wall between the shooter and the target, but the barrage lands behind it). Link to comment Share on other sites More sharing options...
dswanick Posted March 14, 2013 Share Posted March 14, 2013 1. You really need to buy a rulebook, instead of asking questions which are clearly covered in it. 2. The +Official Rules+ forum is for asking rules questions. This forum is for modeling-related discussions. Link to comment Share on other sites More sharing options...
Wraith776 Posted March 14, 2013 Author Share Posted March 14, 2013 i have a rule book but i couldn't find it in the book. Thanks for the help. And sorry i didn't know there was a section for rule questions. Link to comment Share on other sites More sharing options...
Lysere Posted March 14, 2013 Share Posted March 14, 2013 Take the time to look around the forum and learn where things are before posting something, also don't hesitate to use the search function. Simply questions can usually be found quite easily and if you don't find it you at least know which forum to post under. Link to comment Share on other sites More sharing options...
