c'tan phase sword question
Dusktiger
with how power weapons are described now, im wondering how these would be treated.  the description says its a power weapon that will automatically cause instant death regardless of target's toughness.
so does it use the Str User; AP 3 of special power weapons, or can you use any of the 4 power weapon types as a C'tan phase sword and gain the instant death bit on top of them?
https://bolterandchainsword.com/topic/272841-ctan-phase-sword-question/
It says in the BRB that the weapon will use the rules described with it, or by how the weapon looks...... a ctan phase sword, would use sword rules.
Unless you know it is a special power weapon, which is what the OP was asking. Is the C'tan phase sword a special power weapon that causes instant death, or  is it just another power weapon that causes instant death.
If a model's wargear says it has a power weapon which has
no further special rules,
The C'Tan Phase Blade has further special rules. So falls under the Unique Power Weapon section.
If a power weapon has its own unique
close combat rules, treat it as an AP 3 Melee weapon with the
additional rules and characteristics presented in its entry.
So is dantes ax but that one is just a plain power ax with special rules. God knows what is legal with the sword.
easiest way is to take the actualy good faqed vindicator instead of the calidus.
GW FAQed Dante's Axe.
The C'Tan blade is obviously an Unusual Power Weapon.  If it isn't then there are *no* unusual Power Weapons.
A Nemesis Force Halberd is just a normal Power Weapon that also gives you +2 Initiative.  A Frost Balde is also a normal Power Weapon that also gives you +1S.  Etc, etc.
A Nemesis Force Halberd is classified as an Unusual Force Weapon is it not?
I do believe the categorisation as 'Unusual' is saved for any weapon that does not share it's rules with any other weapon in the game. Dante's axe is simply a Master-Crafted weapon if I remember right; many weapons share the Master-Crafted rule in 40k, thus denying it 'Unusual' status. The C'Tan Phase Sword is 'Unusual' in that it grants Instant Death; a trait not shared by any other Power Weapon that I can think of.
but it didnt faq the ctan blade. When the first chaos faq came out everyone knew that NM should be errated , but for that to actualy happen we had to wait for the next faq . the problem is not what you think the ctan blade is , but what the GK codex rules say about the ctan blade . and it says it is a power weapon with ID ability . And power weapons come in 4 shapes and sizes .
No Jeske.  You're wrong.
A C'Tan Blade *is not* a normal Power Weapon that also lets you cause ID when it wounds.
As it's a Power Weapon with an additional ability, therefore it's an Unusual Power Weapon.  This doesn't require a FAQ.
As said, if it's a 'normal' power weapon, but it just lets you do something else as well, then *every* Power Weapon is a 'normal' power weapon, and there *are no* unusual power weapons.
If a model's wargear says it has a power weapon which has no further special rules
Isntant Death is a special rule.
This is clear as day...
Edit: Look at the Codex entry for a C'Tan Blade.
This is a Power Weapon. Additionally
the thing is, GL, a C'Tan Phase Blade doesn't exist. It's a C'Tan Phase Sword. Quite frankly, I find it a bit sad that it would be argued to be another type of weapon. I'd let another player use it as an axe or whatever, because I don't think it's game breaking, but that would definitely negatively influence my opinion of said player...
