Retributis Posted April 2, 2013 Share Posted April 2, 2013 Hi there guys, I've just bought a pot of White Scar paint from my local hobby store and on opening the pot it's all lumpy :( Now I've bought a pot of this paint before from a GW Store and it was the same (but unfortunately by the time I'd got round to using it I'd lost the receipt) so is this just a general problem with white scar and I need to mix it like a madman or am I getting bad luck and duff pots? Also, any ideas on how to revive a pot like this or am I stuck buying another one/making do? Link to comment https://bolterandchainsword.com/topic/273621-white-scar-paint-issues/ Share on other sites More sharing options...
S.k.i.t.t.l.e Posted April 2, 2013 Share Posted April 2, 2013 Had you shook the hell out of it before you looked inside? Make sure you do for at least 2 minutes (time it, it's a lot longer than you think) before you use it. They've been sitting on a shelf for a while and the pigment is probably gathered at the bottom of the pot. Shake it, if still no good, try stirring in a little water or even some matt medium (GW sells it as Lahmian Medium) and give that a go. Good luck dude. Link to comment https://bolterandchainsword.com/topic/273621-white-scar-paint-issues/#findComment-3341286 Share on other sites More sharing options...
S.k.i.t.t.l.e Posted April 4, 2013 Share Posted April 4, 2013 Hey dude. any luck with your paint yet? Link to comment https://bolterandchainsword.com/topic/273621-white-scar-paint-issues/#findComment-3342642 Share on other sites More sharing options...
Dosjetka Posted April 4, 2013 Share Posted April 4, 2013 Had the same problem and had to shake it like hell. Worked, but the consistency of the paint is still a bit weird. Ah well :rolleyes: Link to comment https://bolterandchainsword.com/topic/273621-white-scar-paint-issues/#findComment-3342679 Share on other sites More sharing options...
