Plasma syphons
Brother Bobert
So flipping through the new filthy xenos book I'm thinking the plasma syphon will be a bit more reasonable. Enough of their stuff has plasma under the fluff as well as most of the MEQ lists recently have been steering away from melta and relying on more plasma attacks not to mention all of the plas dark angels can through around.
So other then Inwuisitors attached to a melee squad what could be a good way to field a plasma syphon?
https://bolterandchainsword.com/topic/273821-plasma-syphons/
Highlighted by premeasuring and the ability to move and Rapid Fire.
A use would be to styme the 'stand still and get an extra shot' power.  Move your Syphon into range, and they either stand still at BS1, or move and lose the extra shot.
Or, they stand still and use Marketlights to bump up the BS1 from the Syphon.
Syphon sucks versus Tau. ;)
  • 2 weeks later...
Syphon has 12" range. Pulse weapons are 15" (rapid fire pulse rifles), then 18", then 30". It'll so rarely come up, the Tau player can easily negate it by staying out of range of the syphon.
When did Rapid Fire become half the weapon's maximum range? I could be wrong but I don't believe that's ever been the rule. Rapid Fire range is 12", regardless of the weapon's maximum range is it not?
Check the 6th ed rule book again. You'll find a number of changes to rapid fire.
