Rilian Posted April 10, 2013 Share Posted April 10, 2013 I bought the Chaos Space Marines codex lately and came up with some questions. Forgive me if those are the noobish ones, but I'm new to chaos and was always the imperial guard player. 1. When my daemon prince is attacking with a daemonic weapon and he uses the smash rule, do I add the attacks from the weapon? If not, do I need to roll, to see if my deamon prince lost a wound? 2. How much toughness have the plague marines have? Stats say it's 5 but the special rules says, that they got the mark of nurgle (which gives +1T). Basicly the same question applies to the khorne berserkers. They got the mark of khorne in the special rules entry but they don't have rage there. Do they have the rage special rule, or not? Link to comment Share on other sites More sharing options...
Grey Mage Posted April 10, 2013 Share Posted April 10, 2013 2+3: Generally speaking stat increases from wargear are shown in the profile, special rules granted are not. So yes, they have rage, and yes they are T5 not T6. As for the Daemonweapon.... I see nothing in the FAQ or chaos book that would change it so you halve their base attacks, and then add additional attacks as normal. Wich means you roll as normal. Though I must admit, for some reason Im having an improbably hard time finding the daemon weapon rules. Are you talking about C:Daemons by chance? Link to comment Share on other sites More sharing options...
Rilian Posted April 10, 2013 Author Share Posted April 10, 2013 It's a chaos space marines weapon. CSM codex page 30: "Daemon weapon: At the start of each Fight sub-phase during which the bearer of a daemon weapon is locked in combat, roll a D6. On a roll of a 1, the model emmediately suffers a wound with no armour saves allowed and his weapon skill is 1 until the end of tha phase. On a roll of 2+ the bearer gains that many additional attacks until the end of the phase." So if I charge having 5 base attacks and decide to make a smash attack I have 3 base attacks (5/2=3 or 2?) +1 from charging +D6 from weapon? Link to comment Share on other sites More sharing options...
Interrogator-Chaplain Ezra Posted April 10, 2013 Share Posted April 10, 2013 Smash question: halve the Attack stat (in this case 5), then add the extra Attacks from charging and the weapon. Q: The rulebook says that you halve your Attacks characteristic if you perform a Smash attack. However, if a Monstrous Creature has an uneven number of Attacks, (3 for example), but has charged that turn, does it receive the bonus Attack for charging before or after halving its Attacks? (p42) A: You halve the model’s Attacks characteristic first, then apply any additional modifiers. In the example above, the model would halve its Attacks first (rounding up to 2), then receive a bonus Attack for charging. Link to comment Share on other sites More sharing options...
Fibonacci Posted April 10, 2013 Share Posted April 10, 2013 So if I charge having 5 base attacks and decide to make a smash attack I have 3 base attacks (5/2=3 or 2?) +1 from charging +D6 from weapon? Correct. And 5/2 = 3 since you round up. It is helpful to remember the standard order for applying modifier. Multiplication Additions Set values In this case the multiplier is 0.5 for Smash. The additions are +1 from the charge +d6 from the daemon weapon. There is nothing that sets the value in this scenario so it gets 4+1d6 attacks. Link to comment Share on other sites More sharing options...
