Chef Wulfen Posted April 10, 2013 Share Posted April 10, 2013 I was looking in a local modeling store at some sandbag and walls for basing and I was wondering what the scale I should use for it. I was looking at the 1/35, I'm not sure if that would be to big. Thanks for the comments Link to comment https://bolterandchainsword.com/topic/273986-basing-scales/ Share on other sites More sharing options...
Gurth Posted April 10, 2013 Share Posted April 10, 2013 Some 1/35th-scale military accessories work fine with GW models, others will look very out of scale. Plastic sandbag sets are best avoided, if you ask me, for several reasons: one is that the bags tend to be on the large side even for the scale they're supposed to be (1/35th in this case), while another is that they hardly ever look realistic (a wall made of them will look a bit like someone piled bags of already-set concrete on top of each other). Last but not least, sandbag walls are very easy and cheap to make out of self-hardening clay such as DAS, which will allow you to make walls in any shape and size you like, and they'll look much more realistic to boot. Link to comment https://bolterandchainsword.com/topic/273986-basing-scales/#findComment-3347069 Share on other sites More sharing options...
High Marshall ulrick Posted April 10, 2013 Share Posted April 10, 2013 I found a site that sells cloth sandbags that you can use to make your own sandbag wall from www.secretweaponminiatures.com Link to comment https://bolterandchainsword.com/topic/273986-basing-scales/#findComment-3347071 Share on other sites More sharing options...
Chef Wulfen Posted April 10, 2013 Author Share Posted April 10, 2013 Alright I saw them at the shop and it was a idea that popped into my head. Thanks Link to comment https://bolterandchainsword.com/topic/273986-basing-scales/#findComment-3347116 Share on other sites More sharing options...
Gurth Posted April 11, 2013 Share Posted April 11, 2013 I found a site that sells cloth sandbags that you can use to make your own sandbag wall from These? TBH, they seem rather pointless to me … self-hardening clay or epoxy putty will get you sandbags that will look more realistic Link to comment https://bolterandchainsword.com/topic/273986-basing-scales/#findComment-3347421 Share on other sites More sharing options...
Chaeron Posted April 11, 2013 Share Posted April 11, 2013 I found a site that sells cloth sandbags that you can use to make your own sandbag wall from These? TBH, they seem rather pointless to me … self-hardening clay or epoxy putty will get you sandbags that will look more realistic However cool - realism isn't essential in that regard, it just has to look the part. Echo the sentiments for clay or putty, and you can just put sand around them to look like some have split. Link to comment https://bolterandchainsword.com/topic/273986-basing-scales/#findComment-3347429 Share on other sites More sharing options...
