spjaco Posted April 15, 2013 Share Posted April 15, 2013 Is it possible to use self adhesive decals instead of the water slide transfers? If so where would you go to get the adhesive paper? Would a good printer be able to handle it? Link to comment https://bolterandchainsword.com/topic/274144-is-it-possible-to-use-self-adhesive-decals-instead/ Share on other sites More sharing options...
Grimtooth Posted April 15, 2013 Share Posted April 15, 2013 Gonna have to be very small and hopefully adhere to the paint without damaging it or just falling off. Link to comment https://bolterandchainsword.com/topic/274144-is-it-possible-to-use-self-adhesive-decals-instead/#findComment-3349803 Share on other sites More sharing options...
Greylocke Posted April 15, 2013 Share Posted April 15, 2013 If you're having issues with water slide transfers you should check two products, one called micro set, the other micro sol. Micro set softens the decal and allows it the smoothly curve to rounded shapes without folding or crumpling. Micro sol is a solvent that bonds the decal to the paint under it almost like it's been painted on. It also removes that shiney decal sheen that looks so bad. Both are fairly inexpensive and easy to use. Link to comment https://bolterandchainsword.com/topic/274144-is-it-possible-to-use-self-adhesive-decals-instead/#findComment-3350296 Share on other sites More sharing options...
Forté Posted April 15, 2013 Share Posted April 15, 2013 Practice with the waterslide ones that you don't like on a left over piece of mini. Self adhesive ones will likely be a bit on the thick side. Link to comment https://bolterandchainsword.com/topic/274144-is-it-possible-to-use-self-adhesive-decals-instead/#findComment-3350310 Share on other sites More sharing options...
spjaco Posted April 17, 2013 Author Share Posted April 17, 2013 Thanks for the advice brothers. I cant wait to try these ideas out. Is Micro Set and Micro Sol available at Micheals stores or ??? Link to comment https://bolterandchainsword.com/topic/274144-is-it-possible-to-use-self-adhesive-decals-instead/#findComment-3351243 Share on other sites More sharing options...
Max_Dammit Posted April 17, 2013 Share Posted April 17, 2013 I have access to a vinyl cutter at work and made my own decals using black car vinyl. i'v pushed it as small as can be and works great, but alas not something most people got access to . Link to comment https://bolterandchainsword.com/topic/274144-is-it-possible-to-use-self-adhesive-decals-instead/#findComment-3351400 Share on other sites More sharing options...
Greylocke Posted April 17, 2013 Share Posted April 17, 2013 Thanks for the advice brothers. I cant wait to try these ideas out. Is Micro Set and Micro Sol available at Micheals stores or ??? I'm not sure about Micheals, I don't have one near me. I've ordered it on-line before straight from Micro-scale industries and also from Amazon. I've also have my FLGS order me the Testors version that works just as well. If you have a model train store close to you they normally have it on the shelves. It's used heavily by train folk to make professional looking decorations on their engines and box cars. Some advice from experience, when you're using these products is to have a brush that you mark out just to be used for them. You can't clean all the solvent out and it might mess with some of your paint later if you re-use the same brush. There's lots of awesome u-Tube tutorials out there too. Link to comment https://bolterandchainsword.com/topic/274144-is-it-possible-to-use-self-adhesive-decals-instead/#findComment-3351549 Share on other sites More sharing options...
