Rune Priest Ridcully Posted April 17, 2013 Share Posted April 17, 2013 I have thought about using some Fenrisian wolves, and whilst I like the models, they are quite expensive, so I was wondering if anyone knew of a good priced alternative? Link to comment https://bolterandchainsword.com/topic/274249-cheap-fenrisian-wolves/ Share on other sites More sharing options...
Blacksad Posted April 17, 2013 Share Posted April 17, 2013 get a cat, have it hunt mice, and stuff them? Link to comment https://bolterandchainsword.com/topic/274249-cheap-fenrisian-wolves/#findComment-3351436 Share on other sites More sharing options...
Wulfebane Posted April 17, 2013 Share Posted April 17, 2013 Cardboard cutouts...?Any alternatives bearing any sort of likelihood to fenrisian wolves will be similarly priced unless you can luck out on ebay. Link to comment https://bolterandchainsword.com/topic/274249-cheap-fenrisian-wolves/#findComment-3351447 Share on other sites More sharing options...
dswanick Posted April 17, 2013 Share Posted April 17, 2013 GW sells TLotR Wild Wargs - $18 for 6. Mythicast used to carry packs of wolf minis, but i don't currently see them on the website. Link to comment https://bolterandchainsword.com/topic/274249-cheap-fenrisian-wolves/#findComment-3351455 Share on other sites More sharing options...
Durfast Spiritwolf Posted April 17, 2013 Share Posted April 17, 2013 The Wild Wargs mix in very well, I think, but the price is normally the same per model. Link to comment https://bolterandchainsword.com/topic/274249-cheap-fenrisian-wolves/#findComment-3351502 Share on other sites More sharing options...
dswanick Posted April 17, 2013 Share Posted April 17, 2013 The Wild Wargs mix in very well, I think, but the price is normally the same per model. Uhh, Wild Wargs are $18 for 6 = $3@ Fen.Wolves are $25 for 5 = $5@ You might be thinking of Fell Wargs, which are $30 for 6 = $5@. Link to comment https://bolterandchainsword.com/topic/274249-cheap-fenrisian-wolves/#findComment-3351514 Share on other sites More sharing options...
Wulfebane Posted April 17, 2013 Share Posted April 17, 2013 I guess if you're into that sort of necessity for saving a couple bucks (wrong game imo) you could go with chaos warhounds at $25 for 10. Link to comment https://bolterandchainsword.com/topic/274249-cheap-fenrisian-wolves/#findComment-3351518 Share on other sites More sharing options...
dswanick Posted April 17, 2013 Share Posted April 17, 2013 I guess if you're into that sort of necessity for saving a couple bucks (wrong game imo) you could go with chaos warhounds at $25 for 10. You could, but they require some more modeling work to get looking right and they don't come with the proper base (an additional expense). But look at it this way. By doing Wild Wargs instead of Fen.Wolves, if you fielded just 1 full strength unit of 15 you save $20 and have 3 more models. If you wanted to play a Canis crazy list of 6 units as Troops, you're saving $180. Link to comment https://bolterandchainsword.com/topic/274249-cheap-fenrisian-wolves/#findComment-3351535 Share on other sites More sharing options...
Greylocke Posted April 17, 2013 Share Posted April 17, 2013 There's a company called Iron Wind Metals that makes a 25mm Wolf Pack (7 models) for $18.50. That would be about $2.65 per mini. Link: http://ironwindmetals.com/store/ Or Ral Partha has a 7 wolf pack for £9.95. Sorry I'm a barbaric American and don't know what the conversion is. Link: http://www.ralparthaeurope.co.uk/shop/ You would still have to base them, but instead of buying pre-made GW bases you could cut your own from balsa wood with a compass or template and a sharp hobby knife. With a little sand paper and elbow grease you could even bevel the edges as well! Hey,sometimes going inexpensive requires a little more work, right? For Russ! Link to comment https://bolterandchainsword.com/topic/274249-cheap-fenrisian-wolves/#findComment-3351559 Share on other sites More sharing options...
Durfast Spiritwolf Posted April 17, 2013 Share Posted April 17, 2013 The Wild Wargs mix in very well, I think, but the price is normally the same per model. Uhh, Wild Wargs are $18 for 6 = $3@ Fen.Wolves are $25 for 5 = $5@ You might be thinking of Fell Wargs, which are $30 for 6 = $5@. Ah, you're right, I am. I recognise my failing and will be sure to correct it. Link to comment https://bolterandchainsword.com/topic/274249-cheap-fenrisian-wolves/#findComment-3351742 Share on other sites More sharing options...
The Sandman Posted April 17, 2013 Share Posted April 17, 2013 For my shall we say more renegade space wolves, I've used the fantasy vampire counts dire wolves. Double the models in the box for 50 pence price increase in comparison to the fenrisian wolves from GW when I bought them. That and they look fairly threatening to boot Link to comment https://bolterandchainsword.com/topic/274249-cheap-fenrisian-wolves/#findComment-3351794 Share on other sites More sharing options...
Deathscream Posted April 17, 2013 Share Posted April 17, 2013 Ridcully, have you tried Amazon.com? I saw 4 boxes on there not to long ago for about 20 US dollars each... End of Line Link to comment https://bolterandchainsword.com/topic/274249-cheap-fenrisian-wolves/#findComment-3351795 Share on other sites More sharing options...
WG Vrox Posted April 17, 2013 Share Posted April 17, 2013 Check out toy stores, you might find a wild animal plastic set that contains wolves or dogs of the right size. Link to comment https://bolterandchainsword.com/topic/274249-cheap-fenrisian-wolves/#findComment-3351797 Share on other sites More sharing options...
ORKILL Posted April 17, 2013 Share Posted April 17, 2013 Warhammer Fantasy Goblin Wolfriders... Link to comment https://bolterandchainsword.com/topic/274249-cheap-fenrisian-wolves/#findComment-3351823 Share on other sites More sharing options...
Nadir Posted April 17, 2013 Share Posted April 17, 2013 Yeah, good ol' goblin wolf riders. UI still have about 15 of them. They are cheap on ebay Link to comment https://bolterandchainsword.com/topic/274249-cheap-fenrisian-wolves/#findComment-3351858 Share on other sites More sharing options...
Forté Posted April 18, 2013 Share Posted April 18, 2013 That's because the old goblin wolves are horrible. Just saying. Link to comment https://bolterandchainsword.com/topic/274249-cheap-fenrisian-wolves/#findComment-3352112 Share on other sites More sharing options...
Grey Mage Posted April 19, 2013 Share Posted April 19, 2013 Go to the kids toystore at your local mall. The one with the puzzles, plushies, and lego-knockoffs all over the place. They have little animals there. Check it out- if youre lucky you can find ones about the right size for .75 cents to a dollar a piece, glue to a base, and voila! Link to comment https://bolterandchainsword.com/topic/274249-cheap-fenrisian-wolves/#findComment-3352941 Share on other sites More sharing options...
DanPesci Posted April 19, 2013 Share Posted April 19, 2013 goblin wolves are a good cheap way of playtesting whether you want to use fenrisian wolves long term, without having to cough up lots of cash. Id really like more FW in my army, but at 5 models a box, its expensive and i feel your pain! Link to comment https://bolterandchainsword.com/topic/274249-cheap-fenrisian-wolves/#findComment-3352948 Share on other sites More sharing options...
irwit Posted April 19, 2013 Share Posted April 19, 2013 Surely chaos hounds? You get 10 for the price of 5 fenrisin wolves and the models are so much better ! Link to comment https://bolterandchainsword.com/topic/274249-cheap-fenrisian-wolves/#findComment-3353072 Share on other sites More sharing options...
Wolf Guard Dan Posted April 20, 2013 Share Posted April 20, 2013 yup I use chaos warhounds. after some filing and green stuff, they look pretty good. just have to get some bases. my flgs has some of the right size Link to comment https://bolterandchainsword.com/topic/274249-cheap-fenrisian-wolves/#findComment-3353536 Share on other sites More sharing options...
Kassill Posted April 22, 2013 Share Posted April 22, 2013 GW sells TLotR Wild Wargs - $18 for 6. Mythicast used to carry packs of wolf minis, but i don't currently see them on the website. Yeah, I messaged him a few months back asking if they still made him and he said sadly no. Though he did say he was hoping to bring them back at some point, his focus was on other products. I've got a few (came with the "War Wolf" mounts) and I'm just wondering how off they will look with GW fen wolves. Link to comment https://bolterandchainsword.com/topic/274249-cheap-fenrisian-wolves/#findComment-3355101 Share on other sites More sharing options...
