0ldman Posted April 25, 2013 Share Posted April 25, 2013 Hi all, I've written a quick, dirty and above all else simple guide to taking photos of your figures. If this is something you've ever struggled with, please take a look at the article over on my blog: How to Photograph Miniatures Cheers, Dean S.k.i.t.t.l.e, Kierdale and Warpsmith_Johnson 3 Back to top Link to comment https://bolterandchainsword.com/topic/274564-photography-for-dummies/ Share on other sites More sharing options...
S.k.i.t.t.l.e Posted June 20, 2013 Share Posted June 20, 2013 Nice tut. (Also the quote in your signature made me snigger :D) Link to comment https://bolterandchainsword.com/topic/274564-photography-for-dummies/#findComment-3397680 Share on other sites More sharing options...
0ldman Posted June 20, 2013 Author Share Posted June 20, 2013 Thanks! It's a simple scheme, but it does work. There's almost zero "fuss" and the results are reliable and perfectly presentable for websites. Thanks for the feedback. Link to comment https://bolterandchainsword.com/topic/274564-photography-for-dummies/#findComment-3397789 Share on other sites More sharing options...
Hanska Posted June 27, 2013 Share Posted June 27, 2013 Good tutorial. I like how you point out that you don't need expensive gear to take good shots. And you mention the timer. I use a 2 sec timer so I can get my hands off the camera before the shot. I use manual settings with a very small (what is in english) "hole" around F28 to F36 to get a deeper area of focus and it means longer shutter times. Photographing minis can be like sniping, even your own pulse can ruin a shot. I would have added one thing though. As you mentioned something like 5mp is way too big to post on the net. So why take pictures too close from the mini? Even with macro there is something called minimum focus distance, and way too many takes pictures too close so the camera can only focus on the backround, leaving the mini really blurry. I take pictures from about 40cm distance and just crop them with the same software I resize the to net friendly size. Link to comment https://bolterandchainsword.com/topic/274564-photography-for-dummies/#findComment-3402097 Share on other sites More sharing options...
0ldman Posted June 27, 2013 Author Share Posted June 27, 2013 Thanks for the tip! Feedback is always very welcome. Your comments make a lot of sense - if you don't mind I'll update my tutorial to encompass your suggestions about backing off and cropping. Cheers! Link to comment https://bolterandchainsword.com/topic/274564-photography-for-dummies/#findComment-3402221 Share on other sites More sharing options...
