Armfelt Posted April 29, 2013 Share Posted April 29, 2013 If let us say a bunch of terminators penetrates a rhino multiple times, we then start rolling the chart to see what happens. Is it possible for the vechicle to explode several times, though the range of the blast is only rolled once? Link to comment Share on other sites More sharing options...
DarkGuard Posted April 29, 2013 Share Posted April 29, 2013 A vehicle can only explode once, after the first explosion it's replaced with a crater (or just removed). So even if loads of Terminators get a vehicle explodes result, you only roll for it once. Link to comment Share on other sites More sharing options...
Armfelt Posted April 29, 2013 Author Share Posted April 29, 2013 Thanks for your prompt reply. It is/was a bit unclear for us with the books wording and we are gathering arguments. But for me atleast your view of the rule sounds most likely. :) Link to comment Share on other sites More sharing options...
ShadowSong7007 Posted April 29, 2013 Share Posted April 29, 2013 Unless you buy the Michael bay upgrade for the Rhino then it can explode 10-15 times. Link to comment Share on other sites More sharing options...
corlinjewell Posted April 29, 2013 Share Posted April 29, 2013 Unless you buy the Michael bay upgrade for the Rhino then it can explode 10-15 times. Yeah, but that is way overpriced, so I generally don't use it Link to comment Share on other sites More sharing options...
Lysere Posted April 30, 2013 Share Posted April 30, 2013 If all the shots or attacks that caused it to explode happen at shouldn't you technically still roll them all? Obviously only one explosion matters, but at least where I game we tend to roll out for every explosion to see which was greater. Then again that might just be us being different. Link to comment Share on other sites More sharing options...
Disruptor_fe404 Posted May 1, 2013 Share Posted May 1, 2013 We definitely do something similar, where even if we get enough glances and penetrates to HP a vehicle to death, we'll roll the penetrates to see if we explode it. Link to comment Share on other sites More sharing options...
infornography Posted May 2, 2013 Share Posted May 2, 2013 You should always check to see if you get at least one explosion, but if you get an explosion that is all you get, just the one. Rolling mutliple explosion results and keeping the best one isn't how it works either. After the first explosion result there is no more vehicle for subsequent explosions. Link to comment Share on other sites More sharing options...
