Opinions needed, 15mm Land Raider/Leman Russ conversons
Hi guys, I have a dilemma, I am working on making a land raider, my initial idea was using a Char B1 bis (green one) as a land raider and the Mk 4 (grey one) as a Leman Russ for my 15mm Imperial guard, heres my dilemma, the green one makes the better Land raider, but I think it may be to small, the grey one makes the better Leman Russ, but I think the bigger size would be better for the land raider, so which one should be which? What's your opinion, or should I look at other options? If I used the grey as a land raider, I would remove the rivets, but leave them on for a Leman Russ, also the direction the grey one faces would change depending on if it is a Leman Russ or land raider, both will have gun sponsons on the sides, and hull mounted heavy bolters at the front, check my blog for more Picts.
http://2.bp.blogspot.com/-xntmXM92EvI/UYRq-kW2oAI/AAAAAAAAHIs/GRzMyJfNleA/s1600/IMGP0368.JPGpicture[/img]
http://3.bp.blogspot.com/-fVy6o-bLdfw/UYRrBa90LII/AAAAAAAAHJM/9wCHJ9hyT7w/s1600/IMGP0372.JPGpicture[/img]
http://3.bp.blogspot.com/-EGp04G98YIo/UYRrCvaTE5I/AAAAAAAAHJU/mmDr5oWODgs/s1600/IMGP0375.JPGpicture[/img]
link
