FallenAngels123 Posted May 5, 2013 Share Posted May 5, 2013 hey ppl I just wanna know. how do varnishes work?? whats the difference between matt, satin and gloss?? ofcourse matt is matt and gloss is glossy. but satin?? also what will it change on the models??? will it affect colors in anywaY? Would be great if somebody could tell me everything they know about varnishes. And its really embarassing for me to ask this considering i have been painting for 10 years. cheers folks!!;) Link to comment https://bolterandchainsword.com/topic/275010-how-do-different-varnishes-work/ Share on other sites More sharing options...
winterdyne Posted May 5, 2013 Share Posted May 5, 2013 Gloss varnish increases the specular reflectivity of the surface and decreases the diffuse. This means colours will look darker from most angles, but 'hard' highlights will appear very bright. It's a *smooth* surface. So good for metals, and as a surface to decal on. Matt varnish increases the diffuse reflectivity of the surface and decreases the specular. This means colours will look lighter from most angles (pastel like). It's a rough (dusty) type surface, so good for cloth, dry mud, and absolute rubbish to try and decal on. Satin is half way between the two and is closest to the 'natural' paint finish. Should generally be your go-to top coat. I wouldn't advise decalling on it. Link to comment https://bolterandchainsword.com/topic/275010-how-do-different-varnishes-work/#findComment-3364942 Share on other sites More sharing options...
FallenAngels123 Posted May 5, 2013 Author Share Posted May 5, 2013 Thank you so much buddy. That truly truly helped!!! :D any recommendations of good brands to use for satin varnish?? Also using satin varnish do i run the risk of it fogging by any chance? Link to comment https://bolterandchainsword.com/topic/275010-how-do-different-varnishes-work/#findComment-3364955 Share on other sites More sharing options...
