Chaplain Seneca Posted May 8, 2013 Share Posted May 8, 2013 Are they any good. And, are there rules up to date. With 6th. I have a spare contemptor I haven't but yet and want to convert it to chaos, what would you run with Link to comment Share on other sites More sharing options...
GodEmperorOfMankind Posted May 8, 2013 Share Posted May 8, 2013 One of the few chaos units better than the loyalist counterpart (has an extra wound) except it can't take CML, but I'll ignore that. there's an old topic on this here You'll need the rules in IA:apocalypse 2nd ed and the updated 6th ed rules here Link to comment Share on other sites More sharing options...
Xenith Posted May 8, 2013 Share Posted May 8, 2013 Do it. Butcher Cannons are pretty awesome. They also ignore 40% of glances, which is the equivalent of another hull point at least. Link to comment Share on other sites More sharing options...
GodEmperorOfMankind Posted May 8, 2013 Share Posted May 8, 2013 Not having access to IA apoc, can contemptors have butcher cannons? I was of the impression that they were weapons for the decimator? Link to comment Share on other sites More sharing options...
Dark Bjoern Posted May 8, 2013 Share Posted May 8, 2013 Rulewise he can have one. Modelwise you have to change the elbow joints. It was some work to get everything fit together. Okay, you can´t have a CML but you can have a Havoc launcher. Link to comment Share on other sites More sharing options...
Xenith Posted May 8, 2013 Share Posted May 8, 2013 Havoc launcher + Soul burner is a nice pair of S5 blast weapons to deal with light infantry. A plasma cannon would pair well. The contemptor is basically an awesome choice, arm it to compliment your armies weaknesses. Link to comment Share on other sites More sharing options...
Chaplain Seneca Posted May 8, 2013 Author Share Posted May 8, 2013 Cheers. Thanks angel for the link, I'll convert the last contemptor for my chaos army. Link to comment Share on other sites More sharing options...
GodEmperorOfMankind Posted May 8, 2013 Share Posted May 8, 2013 hey we're here to help! Just remember to post pics :) Link to comment Share on other sites More sharing options...
Dark Bjoern Posted May 8, 2013 Share Posted May 8, 2013 The good thing is, that you can use the Butcher Cannon also as a normal Autocannon. Link to comment Share on other sites More sharing options...
Xenith Posted May 9, 2013 Share Posted May 9, 2013 The good thing is, that you can use the Butcher Cannon also as a normal Autocannon. Or use the FW contemptor autocannons and a butcher cannon ;) Link to comment Share on other sites More sharing options...
Nehekhare Posted May 9, 2013 Share Posted May 9, 2013 not, bad, but too expensive to be good. also no option for double butcher cannons or transport to get into cc =/ Link to comment Share on other sites More sharing options...
Chaplain Seneca Posted May 9, 2013 Author Share Posted May 9, 2013 The marine equivalent is so much better. Sucks for chaos, GW and FW seen to be in tandem with if its got chaos in front of it lets make it worse. But f.em, butchers behind a agies line with quad gun. Does the contemptor gain sky fire. It says AA if it stands still but I'm unsure if that becomes sky fire. Link to comment Share on other sites More sharing options...
Nehekhare Posted May 9, 2013 Share Posted May 9, 2013 IA aeronautica p. 38: If the Contemptor-Mortis remains stationary in the Movement phase, it gains the Skyfire and Interceptor special rules for that turn. and it costs 40pts less than the chaos version... Link to comment Share on other sites More sharing options...
minionboy Posted May 9, 2013 Share Posted May 9, 2013 Do we know what slot the Chaos Contemptor takes in a FOC? I still haven't found anywhere published by GW to say if it's an Elite or a Heavy Support... Link to comment Share on other sites More sharing options...
Dark Bjoern Posted May 10, 2013 Share Posted May 10, 2013 The marine equivalent is so much better. Sucks for chaos, GW and FW seen to be in tandem with if its got chaos in front of it lets make it worse. But f.em, butchers behind a agies line with quad gun. Does the contemptor gain sky fire. It says AA if it stands still but I'm unsure if that becomes sky fire. I don´t think the loyal one is better. The Inv save of the loyal one depends on if you are in CC or range combat. The CSM one has always the same "Inv"-save and it´s a bit better. IA aeronautica p. 38: If the Contemptor-Mortis remains stationary in the Movement phase, it gains the Skyfire and Interceptor special rules for that turn. and it costs 40pts less than the chaos version... The Chaos Contemptor does not have the option to go Mortis and it does not have the AA rule. You should stop thinking of the Chaos Contemptor as another version of the loyal one. It has different rules to keep a difference between CSM and SM. Do we know what slot the Chaos Contemptor takes in a FOC? I still haven't found anywhere published by GW to say if it's an Elite or a Heavy Support... Good question. I would go for elite. Link to comment Share on other sites More sharing options...
Nehekhare Posted May 10, 2013 Share Posted May 10, 2013 The Chaos Contemptor does not have the option to go Mortis and it does not have the AA rule. You should stop thinking of the Chaos Contemptor as another version of the loyal one. It has different rules to keep a difference between CSM and SM. partly true - the rules are not much different exept for +1HP. the real difference is that the mortis version actually serves a battlefield role that makes sense in the current rules, while the others are just bigger, non-transportable versions of dreadnoughts that nobody fields anymore anyway ;) Link to comment Share on other sites More sharing options...
Xenith Posted May 12, 2013 Share Posted May 12, 2013 The Chaos Contemptor does not have the option to go Mortis and it does not have the AA rule. You should stop thinking of the Chaos Contemptor as another version of the loyal one. It has different rules to keep a difference between CSM and SM. partly true - the rules are not much different exept for +1HP. the real difference is that the mortis version actually serves a battlefield role that makes sense in the current rules, while the others are just bigger, non-transportable versions of dreadnoughts that nobody fields anymore anyway Nobody fields them due to AV12 being weak, and krak grenades combines with the hull points rule. Having AV13 removes kraks from the equation and a chance to ignore glances is great. Link to comment Share on other sites More sharing options...
Nehekhare Posted May 12, 2013 Share Posted May 12, 2013 you get av13 with an ironclad/soul grinder for less points and a drop pod/DS to get it into effective range. without transport, it's just good for shooting, but you get ranged AV13 with a pred for half the points. and even those options are rarely taken because they are not efficient. the chaos one has 4+ against glances but only 6+ against pens, the imperials get 5+ against both (ranged). anything behind an aegis or in ruins gets 4+ against everything ;) Link to comment Share on other sites More sharing options...
Xenith Posted May 13, 2013 Share Posted May 13, 2013 you get av13 with an ironclad/soul grinder for less points and a drop pod/DS to get it into effective range. without transport, it's just good for shooting, but you get ranged AV13 with a pred for half the points. and even those options are rarely taken because they are not efficient. the chaos one has 4+ against glances but only 6+ against pens, the imperials get 5+ against both (ranged). anything behind an aegis or in ruins gets 4+ against everything Erm. The Chaos Contemptor's rule is not a save, it rolls to ignore the effects of glances/pens. If you put a chaos contemptor in cover (ruins) , it gets a 4+ cover, then ignores a glance/pen on a 4+/6+. Link to comment Share on other sites More sharing options...
Nehekhare Posted May 13, 2013 Share Posted May 13, 2013 Erm. The Chaos Contemptor's rule is not a save, it rolls to ignore the effects of glances/pens. If you put a chaos contemptor in cover (ruins) , it gets a 4+ cover, then ignores a glance/pen on a 4+/6+. oO true! totally read over that! this is actually nice. so if it had proper ranged weapon options (more than 1 heavy weapon for 250+pts) , it could stay in cover for 4+/4++... or you equip it to actually kill stuff, for example 2x DCCW/HFlamer/Tzeentch to get 4++ without cover walking into close range... hm...nice, but doesn't really solve the problem I'm afraid =/ Link to comment Share on other sites More sharing options...
Sception Posted May 13, 2013 Share Posted May 13, 2013 Yeah, it's problems are more in the offensive punch for the points category. It doesn't have enough long range firepower to be worth its cost at range, and while it can pile up some respectable close range offense, it lacks the speed or transport needed to get into range with enough time left in the game to actually make use of it. Link to comment Share on other sites More sharing options...
Xenith Posted May 13, 2013 Share Posted May 13, 2013 Erm. The Chaos Contemptor's rule is not a save, it rolls to ignore the effects of glances/pens. If you put a chaos contemptor in cover (ruins) , it gets a 4+ cover, then ignores a glance/pen on a 4+/6+. oO true! totally read over that! this is actually nice. so if it had proper ranged weapon options (more than 1 heavy weapon for 250+pts) , it could stay in cover for 4+/4++... or you equip it to actually kill stuff, for example 2x DCCW/HFlamer/Tzeentch to get 4++ without cover walking into close range... hm...nice, but doesn't really solve the problem I'm afraid =/ A lot of people said they would take chaos dreads if they could take TLACx2 loadout - the butcher cannon is the nearest equivalent, not twin linked, but higher strength, and it does not sacrifice combat ability. I agree that they are probably not the best way to spend 250pts, but they can throw a spanner in the works through being so hard to kill (especially with MoN). Link to comment Share on other sites More sharing options...
Plaguecaster Posted May 13, 2013 Share Posted May 13, 2013 I really like the Contemptor it is everything I want in a dread roughly high av, good save plus being able to take marks. I would either run it with butcher cannon, lascannon or multi melta with mark of Nurgle, one question though with the mark of Nurgle subtracting one from the damage chart does that effectively mean it will never explode or am I just reading it wrong? Link to comment Share on other sites More sharing options...
Sception Posted May 13, 2013 Share Posted May 13, 2013 A lot of people said they would take chaos dreads if they could take TLACx2 loadout - the butcher cannon is the nearest equivalent, not twin linked, but higher strength, and it does not sacrifice combat ability. I agree that they are probably not the best way to spend 250pts, but they can throw a spanner in the works through being so hard to kill (especially with MoN). The problem is that they can be fairly safely ignored, they just don't have the damage output they need to be worth bothering with, and aren't scoring so it isn't enough for them to just survive. A dual reaper dread would hypothetically cost, what, 110 points? 120? Not 250. At that price, I'd want two butcher cannons to even consider it, or to come packaged with some sort of drop pod delivery system. Link to comment Share on other sites More sharing options...
Xenith Posted May 13, 2013 Share Posted May 13, 2013 one question though with the mark of Nurgle subtracting one from the damage chart does that effectively mean it will never explode or am I just reading it wrong? You minus one on the chart, but AP2 or 1 add to the chart. It will never explode from AP3 or worse, AP2 explodes it on a 6, AP1 on a 5+. Link to comment Share on other sites More sharing options...
