to wolf or not to wolf?
Well there are only one fast beast option in the codex there is nIce alternative post currently on how to use them successfully which would be worth your time reading. I find they a bit hit and miss but could see them working in balanced list I have seen several builds which are successful in 6th
My favourite is
4xgh units in transports ,
3x LF units ,
runepriest,
TWL w/fen wolves+twc.
It has a bit of everything and I add a guard ally
in larger games. It has the fast attack cc units in the TWL and TWC (I suppose you could do the TWC riderless if really wanted to) I find the TWC more consistant as they are danger to wider range of foes
you wished you could swap out a LF pack or two for a wolf packs if you wanted. If you do go fen wolf heavy I cant recommend saga of the wolfkin enough it makes a big difference to the them.
Other builds that seem successful are drop pod lists based around this
Logan
3x tda WG units in pods
2+gh units
2+ LF units
Aegis Defence line
Rune priest
I have also seen a few GH spam lists  45-60 GH  but these seem to have become less popular with the chaos codex and its range of AP3 flamers
