What to paint up for ETL II - Army selection help needed!
SW1
You select the unit from the normal unit selection in the book so you can take the full 10 grey hunters.  You also select your wolf guard as a unit using the unit entry in the book.  The wolf guard don't get split off the wolf guard unit and attached to the other units unit just before you play.
So if you are playing in a competition it gives you either and additional unit to use or you can choose to break the unit up and bolster the other units.
If i knew this earlier :) time to re-write some of those lists. The way i see it: Drop pod in 10 gh + 1 wg shoot ect..ect.. what ever survives into your own next turn + the kitted wg... move shoot charge... will be devastating specially with the correct gear on that wg
If i knew this earlier smile.png time to re-write some of those lists. The way i see it: Drop pod in 10 gh + 1 wg shoot ect..ect.. what ever survives into your own next turn + the kitted wg... move shoot charge... will be devastating specially with the correct gear on that wg
O yes it can be a beautiful site. :P
The only problem with this is that there is only space for 10 models in the drop pod. So you can fit in 9 GH's and a WG, but you can't fit in 10 GH's and a WG. So either go with 2 special weapons or 1 special weapon and a WG.
