MadGreeks ETL II WIP Thread
MadGreek
I the Mad Greek answer the call of E TENEBRAE LUX and vow to complete one Furioso Dreadnought with Magna Grapple, Frag Cannon, Blood Fist, and Meltagun, and one Furioso Librarian Dreadnought from Codex Blood Angels of total value of 315 points on or before August 15th. Success will bring eternal glory to the Blood Bulls Chapter and failure will doom me to bear the Badge of Shame until the year-end
https://bolterandchainsword.com/topic/275571-madgreeks-etl-ii-wip-thread/
First, Furioso bits in progress
http://i1056.photobucket.com/albums/t371/MDemetris/ETL%202013/IMAG0920_zpsd5440fd0.jpghttp://i1056.photobucket.com/albums/t371/MDemetris/ETL%202013/IMAG0922_zps7f689e86.jpg
http://i1056.photobucket.com/albums/t371/MDemetris/ETL%202013/IMAG0918_zps4720c630.jpg
I wanted to use one my crested Spartan helmets on his guy, only to discover that the Magna Grapple made that awkward.  Solution, turn the grapple around, drill new holes for the "Magna" bits, and run with it.  I think it came out looking pretty good.  Brass bits on the arm are ForgeWorld Minotaur Brass Etch.  Might add a couple more to the body when done - I'll know when I see it.
My Furioso Libby now.
http://i1056.photobucket.com/albums/t371/MDemetris/ETL%202013/d5ed5513-8e99-49a6-8d52-9245c4988945_zps4e7299f6.jpg
http://i1056.photobucket.com/albums/t371/MDemetris/ETL%202013/253cd589-b7c2-46d3-a84a-54e30f44320e_zps52e52ca2.jpg
http://i1056.photobucket.com/albums/t371/MDemetris/ETL%202013/1_zps167c58cb.jpg
I got replacement arms with special shoulder pads.  Need a good well sized axe for the power weapon.  Still searching, suggestions/recommendations very appreciated.  The left side of the dread in this picture probably looks all messed up.  It is.  I had to mold a new one with Rapid Mold and Green Stuff/Milliput.  The worst of it will be covered by the arm.
  • 1 month later...
OK, so life, work, 2 birthdays, not feeling great, and general malaise got in the way and slowed me WAY down.  BUT, got 1/2 my first vow done.
First, I had to decide between these three shields
http://i1056.photobucket.com/albums/t371/MDemetris/ETL%202013/ShieldDecisions_zps360e7fc2.jpg
Then, as I took the first pictures of my completed Dread, I realized I had not added the Melta.  So, shield painted and added, and Melta attached.  Hope you like the results.
http://i1056.photobucket.com/albums/t371/MDemetris/ETL%202013/IMAG0366_zpscbd544a7.jpg
Full Frontal.  I think I picked the right shield.
http://i1056.photobucket.com/albums/t371/MDemetris/ETL%202013/f1b3eff1-084d-4d76-83eb-afd7eee6624f_zpsb28b5bbf.jpg
Angle to show "reversed" Magna-Grapple to make room for crest
http://i1056.photobucket.com/albums/t371/MDemetris/ETL%202013/IMAG03601_zpse80b95cc.jpg
Brass Etch Key Pattern and Minotaur symbol
http://i1056.photobucket.com/albums/t371/MDemetris/ETL%202013/IMAG0362_zps52da2608.jpg
Modified Frag cannon
That's an impressive result. Great results with your modelling and conversion! I love that.:)
To my taste It's got too much metallic paint but I know your color scheme and to each his own. It's very cool with your ancient Greek theme. The freehand and symbols look great! :tu
Ps: when going for the libby dread, consider giving him an axe. A Dreadnought ignores unwieldy. :)
  • 4 weeks later...
OK, finally, here is the 2nd Dread, the Libby, finished.
http://i1056.photobucket.com/albums/t371/MDemetris/ETL%202013/IMAG0476_zpsa138a0f2.jpg
http://i1056.photobucket.com/albums/t371/MDemetris/ETL%202013/IMAG0478_zpsdf8e9634.jpg
http://i1056.photobucket.com/albums/t371/MDemetris/ETL%202013/IMAG0479_zps1c9ffed9.jpg
OK, so obviously, custom head, special order arms, cut the hand up so the fingers could close around the axe, made the axe, brass etch mino head on shoulder scroll, and added a simple shield/lambda symbol to right (left as you look) greave.  Also, tried for a swirly pattern on the axe, cause thats how I kinda see the warp "flowing" when I read descriptions in books.  Didn't come out quite like I wanted, but I will try and improve it,  But for now, I need to be finished.  Hope you like it.
OK, think I can do this.  Not much, but all I have "ready."
I the Mad Greek answer the call of E TENEBRAE LUX and vow to complete one Devastator Squad with Heavy Bolter, Plasma Cannon, Missile Launcher, and Las Cannon from Codex Blood Angels of total value of 150 points on or before August 15th. Success will bring eternal glory to the Blood Bulls Chapter and failure will doom me to bear the Badge of Shame until the year-end
Raw materials
http://i1056.photobucket.com/albums/t371/MDemetris/ETL%202013/IMAG0484_zps9bc14766.jpg
My special Heavy Bolter and Missile Launcher
http://i1056.photobucket.com/albums/t371/MDemetris/ETL%202013/IMAG0485_zps177cc2cb.jpg
And a little blue tac dry fitting.  kneeling legs will be Sgt or missile guy, not sure which yet.
http://i1056.photobucket.com/albums/t371/MDemetris/ETL%202013/IMAG0506_zps01c954f3.jpg
Ignore the Dread in the background.  Working on an allied Ironclad at the same time.
OK.  My Sgts have special shoulder pads, but the Signum I want to use has a molded shoulder pad.
http://i1056.photobucket.com/albums/t371/MDemetris/ETL%202013/fd46ec44-54c2-46bf-9168-4ce6d47d9175_zps5005b2fe.jpg
Wheres my knife?
http://i1056.photobucket.com/albums/t371/MDemetris/ETL%202013/IMAG0507_zps33ce1312.jpg
Trimmed, primed, and now dry fitted.
http://i1056.photobucket.com/albums/t371/MDemetris/ETL%202013/IMAG0508_zpsec8a06cb.jpg
Working a little fast to get done.
OK, first coat Plasma Gun, Missile launcher, and Sgts Signum.
http://i1056.photobucket.com/albums/t371/MDemetris/ETL%202013/c6f75b44-d104-49c8-a509-75508640ce58_zpsdd1708ee.jpg
Powerpack and missile launcher gonna need some adjusting to fit well
http://i1056.photobucket.com/albums/t371/MDemetris/ETL%202013/IMAG0515_zps9728acdc.jpg
http://i1056.photobucket.com/albums/t371/MDemetris/ETL%202013/IMAG0514_zps1bed429b.jpg
OK, Sgt Done.  Plasma Cannon needs shoulder pad and basing.  Also, got some more paint on the missile launcher and arms.
http://i1056.photobucket.com/albums/t371/MDemetris/ETL%202013/IMAG0518_zpsa3a3adc7.jpg
Close up of the wiring, think it came out pretty good.
http://i1056.photobucket.com/albums/t371/MDemetris/ETL%202013/IMAG0517_zps5aa6abd3.jpg
Although now I see a couple spots I missed, and I need to shade that blue cable a bit.
And Missile Launcher body primed, as well as rest of the shoulder pads.
http://i1056.photobucket.com/albums/t371/MDemetris/ETL%202013/IMAG0519_zps4babbbeb.jpg
http://i1056.photobucket.com/albums/t371/MDemetris/ETL%202013/IMAG0522_zps07579127.jpg
K, ML body base coated. Lascannon started. Color added to missiles. There are 3 different missiles that come with the set, 2 are on this figure. There is one with an old fashioned grenade texture that I might slip on the empty rail, paint green, and call Frag, the 1 red tip probably call Krak, since it as a protruding contact fuse that looks like it is for vehicle pen, and the third Ill call Skyfire, in hopes of getting them soon thumbsup.gif Just need a tip color for the Skyfire.
Lascannon done, that brings total to 3 out of five.  ML Marine body shaded, base done.  Arms to be attached soon.  Heavy Bolter, Bolter body, power pack, primed.  In the upper right corner is the Frag Missile to add to ML.
http://i1056.photobucket.com/albums/t371/MDemetris/ETL%202013/IMAG0525_zpsf98e4c5b.jpg
Close up of primed H Bolter
http://i1056.photobucket.com/albums/t371/MDemetris/ETL%202013/IMAG0523_zps6b692ba5.jpg
