Stripping
The bad news is that these paints ar often oil based which means they have thinners that tend to etch plastic.
The good news is if is color to clear changing, there will be a base coat under the color changing paint that will have protected the plastic from the thinners.
Start with the household degreaser method.  Simple Green, Purple Power, Faery Power Spray, Detol, etc.  This will not harm the model at all so you may as well give it a shot.  Soak for 24 hours and then wash it off with an old toothbrush.
https://bolterandchainsword.com/topic/275768-stripping/#findComment-3375944
