Wolf banner and double dice rolls?
Roma
Wolf Standards can only be used to re-roll dice results of '1'. As such, they can not be used to re-roll leadership tests(as reiterated in the FAQ) because you can not have a result of '1' on 2d6 (result range 2-12). They should, for the same reason, not be able to re-roll charge distances - although a valid argument can be made that charge distance is the product of two or more 1d6 rolls which could each be re-rolled. This all comes down to the specific wording of the Charge roll.
So now that I'm on my laptop instead of my tablet...The Charge Range roll is 2d6 (Difficult Terrain is 3d6, take the two lowest), so the same logic used for Leadership tests should apply to Charge Range rolls - no re-roll for the Standard.
