Roma Posted May 24, 2013 Share Posted May 24, 2013 Just a bit confused, since rules for deny the witch say "unit", does that mean: The entire unit make 1 roll for deny the witch when hit with JOTWW, and if it passes every emember of the unit is safe. OR Does every member hit by the power take an individual deny the witch roll Link to comment https://bolterandchainsword.com/topic/275970-jotww-and-deny-the-witch/ Share on other sites More sharing options...
stinkenheim Posted May 24, 2013 Share Posted May 24, 2013 I'd be inclined to say that the first unit struck by the power makes a single save. If passed then the power is effectively nullified and no hits are scored on the target unit or any that would have been hit beyond it. If the test is failed then the power works as normal. This edition they seem to be implementing a one roll to rule them all type philosophy. Link to comment https://bolterandchainsword.com/topic/275970-jotww-and-deny-the-witch/#findComment-3379460 Share on other sites More sharing options...
Roma Posted May 24, 2013 Author Share Posted May 24, 2013 thanks, It says a unit hit by though, I would believe every unit hit has to roll? Thanks or by unit, did you mean single model in a unit? Link to comment https://bolterandchainsword.com/topic/275970-jotww-and-deny-the-witch/#findComment-3379476 Share on other sites More sharing options...
eyeslikethunder Posted May 24, 2013 Share Posted May 24, 2013 First unit hit gets to roll deny the witch Link to comment https://bolterandchainsword.com/topic/275970-jotww-and-deny-the-witch/#findComment-3379489 Share on other sites More sharing options...
Khine Posted May 24, 2013 Share Posted May 24, 2013 thanks, It says a unit hit by though, I would believe every unit hit has to roll? Thanks or by unit, did you mean single model in a unit? Jaws only needs to See/hit the first model in order to be activated as a psychic shooting attack. That model (and it's unit) are allowed a Deny the Witch roll. Every other model/unit that is on the 24" hairline after the first, is considered to be an effect of the first units weakness. Link to comment https://bolterandchainsword.com/topic/275970-jotww-and-deny-the-witch/#findComment-3379536 Share on other sites More sharing options...
Roma Posted May 24, 2013 Author Share Posted May 24, 2013 thanks Link to comment https://bolterandchainsword.com/topic/275970-jotww-and-deny-the-witch/#findComment-3379541 Share on other sites More sharing options...
ErikThunderclaws Posted May 26, 2013 Share Posted May 26, 2013 And what about Psicho Hoods? Link to comment https://bolterandchainsword.com/topic/275970-jotww-and-deny-the-witch/#findComment-3380611 Share on other sites More sharing options...
Squark Posted May 27, 2013 Share Posted May 27, 2013 Well, Psychic Hoods now just boost deny the witch rolls in a radius around the psyker, so... I'm not sure what the question is. Link to comment https://bolterandchainsword.com/topic/275970-jotww-and-deny-the-witch/#findComment-3381082 Share on other sites More sharing options...
ErikThunderclaws Posted May 27, 2013 Share Posted May 27, 2013 Thanks, Squark, you answer it! Link to comment https://bolterandchainsword.com/topic/275970-jotww-and-deny-the-witch/#findComment-3381171 Share on other sites More sharing options...
