henrywalker Posted May 26, 2013 Share Posted May 26, 2013 i'm building a khorne army and i have a ready supply of bits of guardsmen, i was thinking that khorne might well make a barrier out of piles of dead people. what do you guys think? little too much? Link to comment Share on other sites More sharing options...
Antarius Posted May 26, 2013 Share Posted May 26, 2013 It might work but I think it'll be a LOT of work. Link to comment Share on other sites More sharing options...
Kizzdougs Posted May 26, 2013 Share Posted May 26, 2013 I agree with Atarius, it does sound like a lot of work. Personally I'd use a regular wall or barricade and decorate it with plenty of skulls and slain guardsmen. Maybe even crucify a couple of IG, that would be nice or simply fill any breaches in the wall with a pile of corpses. Either way it sounds like a great idea. Link to comment Share on other sites More sharing options...
AekoldHelbrass Posted May 26, 2013 Share Posted May 26, 2013 I'd say it would be a great conversion! I have no idea how many zombie and skeleton kits you'll have to buy to make it happen... Link to comment Share on other sites More sharing options...
Kierdale Posted May 26, 2013 Share Posted May 26, 2013 If you can do it well, mutilating the parts, adding the odd protruding bone from limbs, etc...then I think it would look extremely good, and very fitting for a Khorne army. Some crucified or skewered foes would make good anchor points for sections of the 'wall' itself. Link to comment Share on other sites More sharing options...
Alexos Posted May 29, 2013 Share Posted May 29, 2013 Before I post this link, I would like to pitch a few ideas to you: Instead of finding a way to make guard bodies fit together, try making a "skeleton" of the wall you want, then glueing guard bits to that. For example, take a piece of card and glue the Guardsmen's body parts to it. Try cutting some torsos and legs in half vertically and gluing the cut halves to the card. You could also make a frame out of leftover Sprue. Now, this link is from the Internet Archive Wayback Machine. If the link doesn't work, there should be a button that says impatient? Just click this and it should work. http://web.archive.org/web/20070906002423/http://us.games-workshop.com/games/40k/chaosspacemarines/terrain/obstacles/default.htm This should give you a good idea or two on how to work this idea. Hope it helps. - Alexos Link to comment Share on other sites More sharing options...
Xenith Posted May 29, 2013 Share Posted May 29, 2013 You'd probably need hundreds of guardsmen to make the what, 24" of walls at 1.5" tall? They're better used as allies. Id just buy an aegis or make a wall, then nail guardsmen to it. Link to comment Share on other sites More sharing options...
Hellios Posted May 29, 2013 Share Posted May 29, 2013 Make a foam wall or something... Cover with bits... Make casts of bits if you are up to it and want to save a lot of $$$. Something simpler would be to add spikes to a wall, and then bits of your friends to the spikes... Remember spikes makes everything into the Chaos version. Anyway... It could look cool but it would take a lot of bits if you don't plan it carefully. Link to comment Share on other sites More sharing options...
feuer_faust Posted June 30, 2013 Share Posted June 30, 2013 The Wall of Martyrs already comes piled with skulls and dead gaurdsmen around the base of it. The aquilas I believe are glue-on, so you could deface them or do icons or somethign instead. Cut the floor down the middle, and now you have a defense line instead of trenches. http://www.games-workshop.com/gws/catalog/productDetail.jsp?catId=cat440312a&prodId=prod1780020a http://www.games-workshop.com/gws/catalog/productDetail.jsp?catId=cat440312a&prodId=prod1780022a Link to comment Share on other sites More sharing options...
