Easy Power Weapons With "Glazing" (NOT GW GLAZE)
A really simple and easy method I found is called glazing (not related to the GW glaze paints however). Start by painting the weapon chainmail. Then take whatever color paint you want to use (I find reds, blues, yellows, oranges, and sometimes greens work best) and thin it WAY down so when you paint it onto your weapon you can barely see it at all. Then use the thinned paint to paint the bottom 90% of the blade, Wait for it to dry, then do the bottom 80%, dry, 70%, etc… until you reach the base of the blade. It gives a cool effect of power radiating from the hilt.
Hope This Helped!
  • 3 months later...
  • 1 year later...
Posted · Hidden by Bryan Blaire, November 8, 2015 - Threadomancy, should have been a PM
Sorry for this Thread Necro but I was wondering if using inks instead of thinning the paint would also do the job?
  • 5 months later...
Posted · Hidden by Bryan Blaire, November 8, 2015 - Threadomancy answer to an already Threadomancy question
Probably not, as inks tend to be translucent and paints opaque. The idea of a glaze medium is to make an opaque a translucent.
