sn33r Posted June 8, 2013 Share Posted June 8, 2013 hello i know we have covered rune priest powers but i was wandering..... if i have two rune priests both had runic armour,bolt pistol,ccw etc and were totally identical, With the leaders of the pack special rule your not allowed to have two with the same wargear, i was going to put both on divination both have primaris and roll for there second powers if i roll both the same ie 4's can i re roll one seing as else they would fail my army list. If so i know the chances are slim but it happened to me on thursday and in the end i had to change from being in runic armour to TDA which is all fine but the list im using is one im going to be using for a 2 day tournament coming up and i wont be able to change it... cheers Link to comment https://bolterandchainsword.com/topic/276589-rune-preist-power-rolls/ Share on other sites More sharing options...
skeletoro Posted June 8, 2013 Share Posted June 8, 2013 Your wargear has to be different, and you must equip them with different (codex) powers. Thats two separate constraints that must both be satisfied separately. This rule doesn't apply to randomly generated brb powers. At all. It's perfectly allowable for two rune priests to get the same random powers, but regardless of whether they were the same or different, the rune priests would have to have different war gear. You can't change your list after rolling psychic powers ;) Link to comment https://bolterandchainsword.com/topic/276589-rune-preist-power-rolls/#findComment-3390024 Share on other sites More sharing options...
Roma Posted June 8, 2013 Share Posted June 8, 2013 Do priests roll 2 powers, or 1 since they are m-lvl 1? Link to comment https://bolterandchainsword.com/topic/276589-rune-preist-power-rolls/#findComment-3390181 Share on other sites More sharing options...
skeletoro Posted June 8, 2013 Share Posted June 8, 2013 They roll 2, but they're psychic level 1. I forget if it says it in the BRB or a faq somewhere. Link to comment https://bolterandchainsword.com/topic/276589-rune-preist-power-rolls/#findComment-3390220 Share on other sites More sharing options...
PupLord Posted June 8, 2013 Share Posted June 8, 2013 They roll 2, but they're psychic level 1. I forget if it says it in the BRB or a faq somewhere. It's in the official 6th edition FAQ for Codex: Space Wolves. Psychic Powers A Space Wolves Rune Priest (including Njal Stormcaller) may use the psychic disciplines found in the Warhammer 40,000 rulebook, instead of those in Codex: Space Wolves. If he does so generate two new powers from the Biomancy, Divination or Telekinesis disciplines (in any combination) before armies are deployed. Psychic level is dependent on the number of psychic powers a psyker can use in one turn, therefore RP's are mastery level 1. Link to comment https://bolterandchainsword.com/topic/276589-rune-preist-power-rolls/#findComment-3390224 Share on other sites More sharing options...
