HH cover art bolters
Daylight
It looks closer than the other three. There was one that had a sickle clip, but was too skinny in the forward area. I'm having a massive brain fart trying to think of what's called. Anyway, that bolter is the Umbra Pattern. If you took the sickle clip and slapped it onto the Tigris, it'd probably be the closest you'd ever get.
Okay, so this is a close up of the bolter in question right?
http://i215.photobucket.com/albums/cc69/bleachit54/bolter1_zps60f96637.png
Okay so would this one look close enough?
http://i215.photobucket.com/albums/cc69/bleachit54/bolter2_zps1183fbd1.png
I admit, crappier than the first one. But is this closer?
http://i215.photobucket.com/albums/cc69/bleachit54/bolter3_zps3896fe51.png
Edit, so far that is photoshopped from a base Tigris, with an Umbra bolt clip and the shoulder from the Phobos, as best as I could manage it.
But yeah, I think this was just a baseline bolter. You're either going to get close or not at all. Unless you want to do some major effort.
Take a Phobos.
Cut the extended barrel with the smaller holes in the front, as well as the extension of the lower piece of casing beyond the (now shorter) barrel of the gun off.
Then you have the bolter in the picture. Slim front profile, but sickle clip with exposed ammo, and the semi-triangular piece where the clip feeds in.
