Firepower Posted July 3, 2013 Share Posted July 3, 2013 OK, so I despise Landspeeder bases. I've got one to make for my ETL vow, and I would really like to get a magnetic base. I've found these at Back 2 Base-ix http://www.back2base-ix.com/index.php?_a=viewCat&catId=54 They're awfully pricey, and I'm not sure which size would be best for a Speeder. I've seen the Magz method here, but I really dislike the look of them and I don't want to take a screw to my models http://www.youtube.com/watch?v=r25DIvhMsOg So simply put, what is the easiest, cheapest, and most effective way to make a magnetic flying base? I've seen some people simply cut the end off of the standard flying base and glue a magnet to it, but that seems like something that would snap off real easily. I've found guides scattered around the net, but almost invariably they're old enough that all the picture links are broken Link to comment https://bolterandchainsword.com/topic/277592-magnetic-flyer-bases/ Share on other sites More sharing options...
Gurth Posted July 3, 2013 Share Posted July 3, 2013 My immediate thoughts: put a magnet in the model, drill out the end of the flying base pillar and glue a steel nail into it so that the hail's head sits on top of the pillar. If you saw off the nail to maybe 3–5 mm long first, you won't have to drill as far into the pillar. Link to comment https://bolterandchainsword.com/topic/277592-magnetic-flyer-bases/#findComment-3405744 Share on other sites More sharing options...
Argun Posted July 3, 2013 Share Posted July 3, 2013 I'd just use a strong magnet in the model, and a magnet that kinda/sorta fits on top of the flyer peg once you remove the tip. Just my $0.02 on the subject. Link to comment https://bolterandchainsword.com/topic/277592-magnetic-flyer-bases/#findComment-3406000 Share on other sites More sharing options...
Brother Maikel Posted July 3, 2013 Share Posted July 3, 2013 One of the guys at my FLGS simply replaced the stem of the flying stand with a steel nail, drilled out the bottom of his models, and glued in a magnet. Paint the stem and it's both barely noticeable and really sturdy. Link to comment https://bolterandchainsword.com/topic/277592-magnetic-flyer-bases/#findComment-3406210 Share on other sites More sharing options...
