xGSTARx Posted August 3, 2013 Share Posted August 3, 2013 B&C I need your help I play my brother on a regular basis and lose on a regular basis. He plays wolves with IG allies an I am having trouble beating his list. He plays full mech with: rune priest 2 X grey hunters double plasma in rhino 1 X grey hunters double melta in rhino 2 X long fangs 3 missles 2 las IG full on veterans in chimeras 5 with 3X plasma 2X melta. 1 x vendetta list size is 1850. having problems beating it, he puts out a lot of shooting each turn and even when I pop things the stuff that gets out has lethal shooting. I have tried pod lists with fragisos and DC, full AV 13 wall and troops to the max. Problem I have is I can pop the armour but what falls out can still shoot me to bits. How would you all deal with this? Link to comment Share on other sites More sharing options...
Pesky Wolf Posted August 3, 2013 Share Posted August 3, 2013 Is this what it has come to? your never going to beat me! Link to comment Share on other sites More sharing options...
Xenith Posted August 4, 2013 Share Posted August 4, 2013 What else is in your army, and what more can you field? Your brother/pesky wolf is using a very optimised list, and you may find it difficult to be able to deal with that. Link to comment Share on other sites More sharing options...
Boomkapow Posted August 4, 2013 Share Posted August 4, 2013 Have you tried using a comms relay? Then you could deep strike a fragioso and something to kill the tank. I think you may just have to go shooty. Predators, whirlwinds, Baals, etc. Also Attack Bikes with a Priest on bike would be solid. Pesky Wolf: Don't be a douche. Link to comment Share on other sites More sharing options...
skawolf Posted August 4, 2013 Share Posted August 4, 2013 Is this what it has come to? your never going to beat me! I believe this post should have had maniacal laughter at the end.... just saying. Have you tried sternguard? 4x combi melta plus melta and 5 with just their bolters. Drop in, combat squad up. melta guys pop transports while bolter guys use vengeance rounds and clean house. You also might want to try jump pack honour guard with plasma guns. These are good anti-power armor options. I can never stress enough how aawesome stern guard are. They are the true utility knife of marine codecs. Link to comment Share on other sites More sharing options...
SnorriSnorrison Posted August 4, 2013 Share Posted August 4, 2013 I advise 2 Baals to deal with the Longfangs. Just drown them in bullets and take them out, one unit at a time. It's very important to get rid of those in 1 turn, so I'd use a Fragioso in a pod for a first turn kill(and First Blood), then use the Baals to take out the other squad.A Stormraven should be a given, also it's very useful to counter the Vendetta, which doesn't negate the 'melter' special rule. So, for the first 2 turns, you should take out his long-ranged shooting and the flyer. Then, it is your taks to repel the attacks of the grey hunters and the veterans.The latter are an easy kill for a Baal once the Chimera is taken out(for which I suggest the Stormraven once it's finished with the Vendetta).Luckily for you, your opponent doesn't use any assault units such as Thunderwolves, so you could use a sizeable unit of Death Company to take the Grey Hunters out in close combat, disembarking from the stormraven(no jump packs). Just some thoughts here, what list do you use? Snorri Link to comment Share on other sites More sharing options...
skawolf Posted August 4, 2013 Share Posted August 4, 2013 I concur that we need to know your standard list you are taking or what you have available to take. Link to comment Share on other sites More sharing options...
xGSTARx Posted August 4, 2013 Author Share Posted August 4, 2013 B&C Core of my army normally: Libby 3x Fragioso's in pods 2x RAS with double melta Have access to other models couple more RAS 2 Baals, vindicator stormraven, sang guard, assault termies and scouts. Also have some wolves but would rather not use them. Also have DC with bolters and two more pods. Link to comment Share on other sites More sharing options...
Boomkapow Posted August 4, 2013 Share Posted August 4, 2013 Have you tried the AV13 Shield? Hide troops behind Vindicator, Baal Preds, etc. When he gets close...Dakka them down and charge with RAS. Also, have you tried sanguinary priests in your assault squads. Should help minimize casualties. Bolter DC in pod should take care of the long fangs. Lastly, if you can minimize the number of turns that vendetta can shoot, you should be in business. Let us know how it goes. Link to comment Share on other sites More sharing options...
Xenith Posted August 5, 2013 Share Posted August 5, 2013 Have you tried the AV13 Shield? He has, it says so in the very first post. Get an icarus lascannon and aegis line. Or one of the new defences. You need to be able to take down that vendetta ASAP so you can have air superiority. Potentially a bastion with icarus, 6-8 man dev squad with 4 missile launchers, have one man use the lascannon. The Quad gun would probably work just as well, if not better. Depends whether you can roll 5's to glance! The defences also protect you from the firepower of your opponent. Link to comment Share on other sites More sharing options...
Morticon Posted August 5, 2013 Share Posted August 5, 2013 Mephiston will chomp through half this list alone. Link to comment Share on other sites More sharing options...
BloodTzar Posted August 5, 2013 Share Posted August 5, 2013 Try to use dual ravens and Meph as it has been suggested Link to comment Share on other sites More sharing options...
Morticon Posted August 5, 2013 Share Posted August 5, 2013 A Raven will be great. A snippy dread even better (raven cargo). Mephy as well as I said. You need a little bit of shooty/mobile support to get the guys out of the vehicles, and then the hard hitters to make sure they go down quick. If you're using a frag dread, then make sure you have a few MM bikers to pop open the rhinos first, then you can flame them to oblivion. Link to comment Share on other sites More sharing options...
Xenith Posted August 5, 2013 Share Posted August 5, 2013 Mephiston will chomp through half this list alone. A Raven will be great. A snippy dread even better (raven cargo). Mephy as well as I said. You need a little bit of shooty/mobile support to get the guys out of the vehicles, and then the hard hitters to make sure they go down quick. If you're using a frag dread, then make sure you have a few MM bikers to pop open the rhinos first, then you can flame them to oblivion. I would have thought the plasma spam would be the rock to meph's scissors? You need a lot of LOS blocking terrain to make it work, otherwise they dismount and fry you. The Podding dread will also be down in T1, so you have to be lucky taking out the transports. I still recommend your own long range firepower. Link to comment Share on other sites More sharing options...
SnorriSnorrison Posted August 5, 2013 Share Posted August 5, 2013 Taking one Fragioso with the Raven is a good way to almost certainly kill one squad of marines, just use the Raven's special rule to drop it on the way while sniping a rhino with the twin-linked MM. It's a bit difficult to pull off, but very effective if it works. Also, with spirit of the machine-whatever, you can try to pop another rhino, especially when in a castled formation. To your list, I'm quite sure 1 Fragioso in drop pod will be enough for a turn 1 strike, because the only worthy targets are the Longfangs. One in the Raven, used as above, can be a one-trick-pony to take out another squad. Also, having a Furioso up front is a good distraction for the remaining Longfangs. I still advise Baals to take out the devastators with concentrated bolter and assault cannon fire. After the Furioso has taken care of the first squad(hopefully), the Baals should blow away the remaining longfangs.Also, try to go second when you can. The vendetta will (probably) come before you, so you can react to its movement and take it down with a mm shot in the side armour. It's also quite nice to let him spread out his forces, so you can lay down some fire or go for a denied-flank movement if necessary. Also, the Furioso in pod will come down after his movement phase, so there's a chance of getting a lucky shot behind enemy lines while the rest of the army moves on. Snorri Link to comment Share on other sites More sharing options...
xGSTARx Posted August 5, 2013 Author Share Posted August 5, 2013 Cheers for the comments guys, What about this: Libby (prescience) Devastators 4 x RAS razorbacks with assault cannons 2x Dakka Baals 1 vindicator Fragioso in pod Snippy furioso Stormraven with hurricane bolters Libby with the Dev's handing out rerolls, Fragiso and Baals for the long fangs. Hope to pop things with razor's and vindicator. Link to comment Share on other sites More sharing options...
Boomkapow Posted August 5, 2013 Share Posted August 5, 2013 Baal preds can also rock the rhinos and the models in them. Plasma glances on 6s. So if the long fangs go down to the fragioso, they would be the targets of the Baal preds I would say. Link to comment Share on other sites More sharing options...
BloodTzar Posted August 6, 2013 Share Posted August 6, 2013 I would suggest this HQ Meph ELITES Furiouso (talons) in SR Fragiouso in SR (can be changed for DP instead of DC) TROOPS 2x5 ASM (melta, Lazor-back) 7 DC (bolters, Axe+BP, PF) in DP FAST 1x Flame Baal 2x AC Baal with HB HEAVY SR (MM AC) SR (MM AC) Hope it helps, ~BT Link to comment Share on other sites More sharing options...
