Artemid Posted August 4, 2013 Share Posted August 4, 2013 Hey all, maybe someone can help me. I've been following and finally went and got what should be mineral spirits (god, I hate Michael's with a passion), Grumbacher Pre-tested Odorless Thinner, but I can really tell that it's not working so hot - the pigments are separating from it while drying and running down panel lines and sinking to the bottom of the mixing cup. It's also not flowing so nicely, but I'm guessing it's not enough varnish on the model... anyone have any idea what I'm doing wrong? Did I buy the wrong stuff? This SHOULD work fine if the pigments would stay properly suspended. edit: yes, it's xenos, but it's what i'm testing on, so I can do it properly on the Emperor's servants. But you can see what I mean: http://imgur.com/a/k3WpX Link to comment https://bolterandchainsword.com/topic/278044-oil-wash-troubles/ Share on other sites More sharing options...
skawolf Posted August 4, 2013 Share Posted August 4, 2013 Yeah, i'm sure the xenos link won't last long Link to comment https://bolterandchainsword.com/topic/278044-oil-wash-troubles/#findComment-3411948 Share on other sites More sharing options...
Artemid Posted August 4, 2013 Author Share Posted August 4, 2013 I mean, I'm not going to go wreck a model I care about to test this stuff on when it's not working, so it's the only thing I have to illustrate the problem. That aside, do you have any direct experience with it? Link to comment https://bolterandchainsword.com/topic/278044-oil-wash-troubles/#findComment-3411955 Share on other sites More sharing options...
Firepower Posted August 5, 2013 Share Posted August 5, 2013 Lately, I've been having a real issue with pigment sinking to the bottom of my mixing palette. I don't recall that being a problem during my testing, when I was using precisely the same paint and spirits, so that's awfully weird. I'm not sure why it's happening exactly, but stirring it vigorously with every dip is enough to keep it flowing fairly well. Still, stirring constantly is a pain, and doesn't work every time, so if someone has an answer I'm also very keen to hear it :) Link to comment https://bolterandchainsword.com/topic/278044-oil-wash-troubles/#findComment-3412021 Share on other sites More sharing options...
skawolf Posted August 5, 2013 Share Posted August 5, 2013 I mean, I'm not going to go wreck a model I care about to test this stuff on when it's not working, so it's the only thing I have to illustrate the problem. That aside, do you have any direct experience with it? Good save good save :D No I have never used this before. The results look good though. Link to comment https://bolterandchainsword.com/topic/278044-oil-wash-troubles/#findComment-3412087 Share on other sites More sharing options...
Lorenzen Posted August 5, 2013 Share Posted August 5, 2013 due to the way oil paint works it will never fully "mix" with the thinner.. however you can buy pre mixed stuff that comes in a bottle from AK interactive, i've been using their streaking grime on my death guard to get the beige colour i was originally getting with oils, because the consistancy is less likely to alter from model to model than with oils. tbh though one of the major advantages of oil washes is that they flow into the creases etc and they can be worked with for a decent amount of time to stop any staining due to pooling etc and tide marks. Link to comment https://bolterandchainsword.com/topic/278044-oil-wash-troubles/#findComment-3412611 Share on other sites More sharing options...
Artemid Posted August 5, 2013 Author Share Posted August 5, 2013 I've already got the paint, I'm not buying a premixed thing so I can have more stuff sit around I'm not using. I'm entirely aware of the advantages of oil washes... that's why I'm trying to use them.... But this stuff is separating mad quick. Before it dries quick. So it's not flowing right either. Link to comment https://bolterandchainsword.com/topic/278044-oil-wash-troubles/#findComment-3412620 Share on other sites More sharing options...
Firepower Posted August 5, 2013 Share Posted August 5, 2013 I went and dropped a line over in dakkadakka to cast a wider net, so to speak. I'll tell you if I get any interesting results out of it. Or I suppose you could just go look for yourself. I have the same screen name (and of course avatar) over there :) Link to comment https://bolterandchainsword.com/topic/278044-oil-wash-troubles/#findComment-3412690 Share on other sites More sharing options...
DarkMark Posted August 6, 2013 Share Posted August 6, 2013 I don't have an exact answer, but after perusing a couple of my favourite modelling sites I came up with some ideas. Often artists' oil have linseed oil in them; this can can separation and other problems. One way to help remove/ lower the amount of this from your paint is to put the paint on cardboard a couple of hours before you need it, so that it can be sucked out. You may also want to wet your gloss vanish coat with a little WS before you apply the wash. Different brands of oil and minerals naturally behave differently. The WS could be attacking the oils aggressively causing a problem. Sadly I'm no expert, but hopefully if we pool out knowledge/ experience we'll come up with something! Link to comment https://bolterandchainsword.com/topic/278044-oil-wash-troubles/#findComment-3413088 Share on other sites More sharing options...
Firepower Posted August 6, 2013 Share Posted August 6, 2013 Having wet WS on the model before a wash actually causes problems, in my experience. It disturbs the flow of the wash, so it won't follow the contours of the model and jump straight into the recesses like it is supposed to. Instead you just get a little puddle where the two meet. Surface tension, and all that junk. I got advice over on dakkadakka which seems curious, in the same vein of oil paint separation. "oil paint can start to separate given time. that sounds like what might be happening, lower pigment and faster dry time because its not mixed properly. knead the tube prior to use. then instead of squirting out a blob, poke a toothpick into the end, swirl it around and draw it out covered in oil paint. hope that helps. " Link to comment https://bolterandchainsword.com/topic/278044-oil-wash-troubles/#findComment-3413182 Share on other sites More sharing options...
Artemid Posted August 6, 2013 Author Share Posted August 6, 2013 I will definitely give that a shot today I think. Or, soon, depends how lazy I feel about cleaning all the captain bits away Probably going to revarnish too to make sure that surface is nice and helpful. Link to comment https://bolterandchainsword.com/topic/278044-oil-wash-troubles/#findComment-3413231 Share on other sites More sharing options...
Artemid Posted August 8, 2013 Author Share Posted August 8, 2013 Didn't help at all. edit: maybe I didn't knead enough, I don't know. Was pretty similar coming out of the tube, but it's coming out fairly solid... Link to comment https://bolterandchainsword.com/topic/278044-oil-wash-troubles/#findComment-3415557 Share on other sites More sharing options...
Artemid Posted August 13, 2013 Author Share Posted August 13, 2013 So I dropped the question on BuyPainted and awesomepaintjob's actual oil wash vids. Les responded today that it means the wash is too thin, which I was starting to wonder, but I have not tested again. Link to comment https://bolterandchainsword.com/topic/278044-oil-wash-troubles/#findComment-3421237 Share on other sites More sharing options...
Firepower Posted August 14, 2013 Share Posted August 14, 2013 But how can one keep it from being too thin if the pigment keeps turning to sediment every 15 seconds...unless my current 'Stir like your life depends on it' methodology is actually how this is supposed to go Link to comment https://bolterandchainsword.com/topic/278044-oil-wash-troubles/#findComment-3422217 Share on other sites More sharing options...
Artemid Posted August 14, 2013 Author Share Posted August 14, 2013 But how can one keep it from being too thin if the pigment keeps turning to sediment every 15 seconds...unless my current 'Stir like your life depends on it' methodology is actually how this is supposed to go :P Presumably, a much lower spirits:paint ratio when pouring and mixing in the first place. I was thinking of trying it drop by drop, but new job means no time yet. Link to comment https://bolterandchainsword.com/topic/278044-oil-wash-troubles/#findComment-3422414 Share on other sites More sharing options...
