GrandMagnus Posted August 19, 2013 Share Posted August 19, 2013 Hi brothers, Im sure this has been asked a 1000 times, but I cant find any thread. So what is good to remove paint from FW resin without dissolving the mini? Ive heard oven cleaner, but Im not sure. Link to comment https://bolterandchainsword.com/topic/278622-removing-paint-from-fw-resin/ Share on other sites More sharing options...
Verbal Underbelly Posted August 19, 2013 Share Posted August 19, 2013 I've used Dettol; it did make some of the model's extremities soft so I wouldn't recommend that. It did remove the paint though... Link to comment https://bolterandchainsword.com/topic/278622-removing-paint-from-fw-resin/#findComment-3427874 Share on other sites More sharing options...
Bongfu Posted August 19, 2013 Share Posted August 19, 2013 LA's Totally Awesome I use it on all minis. Its fast, safe on plastic/resin, and doesn't smell the house up! Link to comment https://bolterandchainsword.com/topic/278622-removing-paint-from-fw-resin/#findComment-3427970 Share on other sites More sharing options...
GrandMagnus Posted August 19, 2013 Author Share Posted August 19, 2013 Verbal underbelly: Hmm, id rather not use anything that makes the minis "bendi". Bongfu: This looks interesting, but Im wondering if I can get it here in Europe. Link to comment https://bolterandchainsword.com/topic/278622-removing-paint-from-fw-resin/#findComment-3428027 Share on other sites More sharing options...
Brother Tankred Posted August 21, 2013 Share Posted August 21, 2013 Fairy power spray in the UK - you can get it in Tesco. Doesn't smell bad and is water soluble. Just make sure you use a soft toothbrush after its been left on for a day (if it needs that long, sometimes a few hours is enough) Link to comment https://bolterandchainsword.com/topic/278622-removing-paint-from-fw-resin/#findComment-3430774 Share on other sites More sharing options...
p34ce Posted August 22, 2013 Share Posted August 22, 2013 Oven cleaner works best, and you don't even have to leave it for a day - two hours is usually enough. Depending on what type of paint is on the model, and how long it's been on the model, it could take two or three separate applications. I think this topic belongs in the General PCA Questions section. Link to comment https://bolterandchainsword.com/topic/278622-removing-paint-from-fw-resin/#findComment-3431132 Share on other sites More sharing options...
GrandMagnus Posted August 22, 2013 Author Share Posted August 22, 2013 Allright, thank you brothers. Ill try using oven cleaner first since thats what I currently have available. If the one Ive got doesnt work (for whatever reason) Ill try and find some of that Fairy power spray. Link to comment https://bolterandchainsword.com/topic/278622-removing-paint-from-fw-resin/#findComment-3431293 Share on other sites More sharing options...
Tanhausen Posted August 22, 2013 Share Posted August 22, 2013 Isopropyl alcohol. Cheap, easy to get a hold of and strips paint and primer like a charm. Y en el Mercadona lo puedes comprar a 3 euros los 1,5L (sección de limpieza, alcohol para limpiar). Hope it helps! Link to comment https://bolterandchainsword.com/topic/278622-removing-paint-from-fw-resin/#findComment-3431374 Share on other sites More sharing options...
GrandMagnus Posted August 22, 2013 Author Share Posted August 22, 2013 Now thats good information, thank you. Link to comment https://bolterandchainsword.com/topic/278622-removing-paint-from-fw-resin/#findComment-3431386 Share on other sites More sharing options...
Marshal Rohr Posted August 22, 2013 Share Posted August 22, 2013 Simple green worked for me Link to comment https://bolterandchainsword.com/topic/278622-removing-paint-from-fw-resin/#findComment-3431772 Share on other sites More sharing options...
Brother Tankred Posted August 22, 2013 Share Posted August 22, 2013 Isopropyl alcohol. Cheap, easy to get a hold of and strips paint and primer like a charm. Y en el Mercadona lo puedes comprar a 3 euros los 1,5L (sección de limpieza, alcohol para limpiar). Hope it helps! Whenever I've tried isopropyl alcohol on set acrylic it wouldn't touch it - go figure. Link to comment https://bolterandchainsword.com/topic/278622-removing-paint-from-fw-resin/#findComment-3432070 Share on other sites More sharing options...
GrandMagnus Posted August 23, 2013 Author Share Posted August 23, 2013 Okay, I tried an oven cleaner, let it sit for 2 hours and it took most of it off but not all. I will have to try Isopropyl. By the way, any ideas how to dissolve glue? Link to comment https://bolterandchainsword.com/topic/278622-removing-paint-from-fw-resin/#findComment-3432787 Share on other sites More sharing options...
Hyaenidae Posted August 23, 2013 Share Posted August 23, 2013 Simple green worked for me Same here. I've used the stuff to nuke quite a few of my models. Link to comment https://bolterandchainsword.com/topic/278622-removing-paint-from-fw-resin/#findComment-3433120 Share on other sites More sharing options...
Adeptus-Alaska Posted August 23, 2013 Share Posted August 23, 2013 I use simple green as well, but be careful, It also will make resin/finecrap minis bendy. some time I use nail polish remeover SPARINGLY, soak for about 20 min. then dip brush in and scrub gently! Link to comment https://bolterandchainsword.com/topic/278622-removing-paint-from-fw-resin/#findComment-3433129 Share on other sites More sharing options...
Firepower Posted August 23, 2013 Share Posted August 23, 2013 Castrol super clean works great for me on plastic (until I through enamel at it) but I dunno how it will perform on resin. Link to comment https://bolterandchainsword.com/topic/278622-removing-paint-from-fw-resin/#findComment-3433401 Share on other sites More sharing options...
GrandMagnus Posted August 24, 2013 Author Share Posted August 24, 2013 EDIT: A quick google search and I know where to find it here. I try to pick up some Simple Green. Link to comment https://bolterandchainsword.com/topic/278622-removing-paint-from-fw-resin/#findComment-3433713 Share on other sites More sharing options...
Molokai Posted August 24, 2013 Share Posted August 24, 2013 I've found the simple green website. Which particular product do you use? Link to comment https://bolterandchainsword.com/topic/278622-removing-paint-from-fw-resin/#findComment-3433878 Share on other sites More sharing options...
