praetor with lightening claws
Daemon2027
Worse comes to worst, you can always just have a holstered weapon. That's what I was always planning to do with the CCW, BP, and Bolter.
But the wrist-mount sounds more fun. To make things easier, maybe you can lop off Abby's arm! It'll be a while before he needs it. tongue.png
What I meant was you can only use two weapons, for example you can't fire a fire a pistol then charge into combat and receive the bonus of having two lightning claws. That's my interpretation of the rules at least. I've always been of the opinion however that using a range weapon when you have two lightning claws is iffy.
But in world of wrist mounted weapons would it not be easier to fire in combat. Can you use a bolter or combi weapon in close combat? I mean it should be possible to shoot at a target when not in combat, then bring up the lightening claws to go all Wolverine on someone once engaged in combat.
I can't see anything to suggest you have to a weapon you shoot in the shooting phase in an assault (e.g. Shooting a pistol and then using a specialist weapon). So no reason why you couldn't fire a wrist mounted Combi-flamer and then charge in with lightning claws.
This.
I have no problem imagining anyone firing their normal ranged weapon then mag locking it and drawing a pistol for close combat, so why not a wrist mounted combi weapon be fired then use the claws in combat?
Where in the *6th ed* rules does it say you can't carry more than 2 weapons? It used to (IIRC) back in 5th (or was it 4th?) but there's no such a rule in place anymore; otherwise marines equipped with Bolter, BP and CCW would be illegal...
A Praetor can take an additional Bolter/Combi/Charger and then swap his BP and CCW for a pair of lightning claws (or for a LC and PF, or whatever else you want...). Go ahead, just make sure you model it appropriately ;)
Remember that if you do take that bolter or volkite charger, you are still under the same restrictions for shooting and charging.  My recommendation would be to take combi-flamer from a rules standpoint.
BUT:  I am assuming that your praetor will be jump packing in with twin lightning claws.  If so, I would not worry about it as much as I would only be shooting at targets I was approaching outside my assault range.
You can change after firing it (only charge at the unit you shot at). So if you have lightning claw mounted Volkite Charger you can fire the two shots and then charge the unit. I really like that idea.
Different for Terminators due to Relentless/slow and purposeful
Thanks for your help guys. Yeah I've got a jump pack twin lightening claws guy, and I thought the extra range attack may be an added bonus. He's obviously a close combat sort of guy, and he will be backed up with a command squad, carrying combat shields and an assortment of power weapons (or maybe the sabres?), and fists. Was going to give him a combi flamer but would the volkite be a better choice?
Depends. Bolter will give you a decent-ish range when not getting into combat. The Combi weapons gives some flexibility. The Volkite charger gives two shots before combat and the range is a bit bigger than charge range (and has the deflagrate rule).
I just think the idea of modelling two Serpenta (when released) on a pair of lightning claws to represent the two shots from a charger is freaking awesome. Add in a jump pack for some more cool imagery.
FYI I rarely play warhammer and never played a 30k game (yet) so don't take my advice on it :)
