Could use some help with my Praetor
The second one is closer to what thought, but the hand needs to remain straight as it looks a bit odd, which would then put the hammer in a weird position. Even if you could turn the hammer head i'm not sure it would look right. I think the arm angle makes positioning the hammer in a natural way difficult. I've just tried replicating the pose in real life and it doesn't feel natural. I think its because the legs are close together, so the extended arm makes it all off balanced. Sorry i have not been very helpfull....
So this is what I have to work with atm, I'm seriously considering cutting off that arm but I'm not sure what to replace it with yet.
http://img855.imageshack.us/img855/3407/6y0g.jpg
http://img703.imageshack.us/img703/9351/qat5.jpg
If you cut off the arm remember the shoulder pad is lined up a certain way so any replacement arm will need to have the upper arm in the same position.
have you thought about him holding a hammer two handed across his body. The right arms is already in the correct position.
How about this?
http://img809.imageshack.us/img809/6135/uoqe.jpg
http://img51.imageshack.us/img51/3859/93r5.jpg
http://img189.imageshack.us/img189/6201/n4nd.jpg
Alternatively I have the forgeworld "round" plasma pistol to if that pistol int he picture ain't quite right, or I could give him a phobos pattern bolter or maybe even get a charge if I order one from a bits store or ebay.
Hmm, I'm not sure on the ranged weaponry, the spear will count as a paragon blade which is a specialist weapon, so he can't get a bonus for using a pistol with it, so I was thinking of going with a volkite charger, which is an assault weapon with the possibility of inflicting four wounds. Where as the plasma pistol is a lot sleeker and smaller, but costs a bit more and I don't think I'll be playing that many space marine forces if I go by who plays what at my local store, so the volkite maybe a better all rounder.
In Vulkan lives there's a picture of Numeon he has a glaive with a volkite weapon on it as well. So I'm thinking maybe I add a volkite weapon to the spear and change the right arm so that he's has a pointing finger instead of a weapon?
Before you cut up his right arm, try lifting the left arm up so he is shooting from the hip, place the hammer/spear in a neutral position and rotate the head to face his shot. Other than that, the first attempt for the leading right spear looks the best, while the hammer could look just as good if it were 45 degrees up; it isn't a cricket bat, try holding a horizontal barbell pointing away from you steady with just one hand sweat.gif.
The main problem with the model is the dysfunction between the legs and the rest of his body; the legs give off a semi active vibe while the body is not holding anything back. If you are not satisfied with your first spear and leading hammer attempt, neither with the hip shot, I would suggest cutting at the waist and sticking in either of the moving legs from the MkIV legion set, instead of cutting the right arm.
Edit: rotate his left arm so he is holding the pistol up in celebration and it throws the torso into a static pose no matter what your right hand does (bar few exceptions).
The artwork in Vulkan Lives shows it very clearly, I'm not sure what to do about the hand though, I'm trying to find a right pointing arm, or at least just the hand. Maybe this?
http://www.bitzbox.co.uk/images/fw_cadian_command_pointing%20arm_large.jpg
Or if I could get hold of just the arm from this model, that would be perfect.
http://www.games-workshop.com/MEDIA_CustomProductCatalog/m2380440a_99800101045_SMChronusCFC01_445x319.jpg
So I've attempted to sculpt a hand using a smaller pointing hand (sorry Marco Colombo) as the base and tried to bulk it up, this is how it looks so far.
http://img89.imageshack.us/img89/4531/ytia.jpg
http://img19.imageshack.us/img19/4925/owi0.jpg
http://img202.imageshack.us/img202/4415/82lb.jpg
