Could use some help with my Praetor
For a moment, it seemed like he's pointing with his middle finger, hehe. Could you give us a closer, sharper look at the hand? It seems nice, may try and thin the finger here and there, but I do like it a lot and it does look perfect in terms of proportion.
BestI could do, it does look like he's pointing with the middle fingure, I'm going to try chop off the bit to right when you look head on to see if that makes it look better.
http://img35.imageshack.us/img35/7206/pxa7.jpg
Looking much better!
Now just rotate the glaive 90* in his hand. It bothers me to no end when weapons are modelled in such a way that if the user took a swing without regripping that they'd smack their foe with the flat (and I know this wasn't your doing).
Do you mean like this?
http://img838.imageshack.us/img838/5891/u66y.jpg
I'm also in the process of getting hold of a Sergeant chronus arm for the pointing hand. At the moment the current hand looks like it only has one finger.
Seems I may have a problem with the Chronus arm since apparently it all comes in one piece, although I'm not sure about the finecast model. I may just get the fine cast, might be able to pick one up at gamesday, fed up of paying their postage fees.
Do you have a little saw. Shouldn't be to hard to cut the hand off.
Edit: oh and he is looking better every time I see him :)
Just another rock, it looked a little awkward without it as it made him look like he was pointing at the stars, I was considering putting an eldar helmet or something else like an Ork head under it.
I'm torn on the overall base, since it's mainly crusade themed it could be anything, I don't really want it to be grey though since my normal marine army is grey with snow and grass. Maybe obsidian or some form of volcanic looking rock?
That glave will look really good.
As for the rock, he is definitely pointing up, but I wouldn't say he is pointing to the stars. If you do keep him on the rock use some green stuff to make it look like the same rock. You could add crystals, have seen that done before.
I have some green crystal rock, kinds of makes me think of warp stone from fantasy, do you mean to cover the crack?
