Emperor's Furor Posted August 24, 2013 Share Posted August 24, 2013 In an effort to get my Praetor just right, I ordered some Volkites Chargers from FW with the thought, I'm a Salamander I'm going to be using them a lot..however when it came to looking for a squad who can use them I realised no squad does, they are basically an upgrade for a bolter, so they ain't the ones used by the support squad or the heavy support squad. Am I right in this or am I missing something? Do you think Salamanders may receive a rule to upgrade their troops to use them rather than Bolters? *crosses fingers* Link to comment https://bolterandchainsword.com/topic/278905-volkite-chargers/ Share on other sites More sharing options...
Adra'Melek Posted August 24, 2013 Share Posted August 24, 2013 Can't the veteran squad have them? Or is it the command squad? Most of the HQ can I think. Link to comment https://bolterandchainsword.com/topic/278905-volkite-chargers/#findComment-3434226 Share on other sites More sharing options...
Emperor's Furor Posted August 24, 2013 Author Share Posted August 24, 2013 They can all have Serpentas but only 1 per 5 can have a charger. Link to comment https://bolterandchainsword.com/topic/278905-volkite-chargers/#findComment-3434239 Share on other sites More sharing options...
Demus Ragnok Posted August 24, 2013 Share Posted August 24, 2013 Aren't Chargers assault 2? And bolters are rapid fire. So the Charger would be the same option as other "assault" weapons. I think the other Volkite weapons are both heavy 1, so that leaves them as support and heavy support. Link to comment https://bolterandchainsword.com/topic/278905-volkite-chargers/#findComment-3434250 Share on other sites More sharing options...
depthcharge12 Posted August 24, 2013 Share Posted August 24, 2013 I believe you can put them on termies for a point increase. but idk how you will do that since the chargers dont have termie hands attached to them Link to comment https://bolterandchainsword.com/topic/278905-volkite-chargers/#findComment-3434281 Share on other sites More sharing options...
Emperor's Furor Posted August 24, 2013 Author Share Posted August 24, 2013 Aren't Chargers assault 2? And bolters are rapid fire. So the Charger would be the same option as other "assault" weapons. I think the other Volkite weapons are both heavy 1, so that leaves them as support and heavy support. The Tactical Support Squads carry the Caliver version, which is weird as you're right it is a heavy version. Shouldn't support squads have assault weapons? Link to comment https://bolterandchainsword.com/topic/278905-volkite-chargers/#findComment-3434284 Share on other sites More sharing options...
Demus Ragnok Posted August 24, 2013 Share Posted August 24, 2013 Aren't Chargers assault 2? And bolters are rapid fire. So the Charger would be the same option as other "assault" weapons. I think the other Volkite weapons are both heavy 1, so that leaves them as support and heavy support. The Tactical Support Squads carry the Caliver version, which is weird as you're right it is a heavy version. Shouldn't support squads have assault weapons? Nah "tactical support" squads are more like "special weapons" squads. They have the options like flamers and plasma and such that are normally 1 per for 40k tact squads. They are there to supplement the tactical squads in their job of "stand and shoot". Its just that tactical support squads can be built to stand and shoot at things bolters alone can't kill effectively. I agree the heavy 1 on the Caliver does set it apart from the other options for the support squad. Link to comment https://bolterandchainsword.com/topic/278905-volkite-chargers/#findComment-3434298 Share on other sites More sharing options...
Emperor's Furor Posted August 24, 2013 Author Share Posted August 24, 2013 I believe you can put them on termies for a point increase. but idk how you will do that since the chargers dont have termie hands attached to them Hmm never thought of that. Link to comment https://bolterandchainsword.com/topic/278905-volkite-chargers/#findComment-3434317 Share on other sites More sharing options...
DuskRaider Posted August 25, 2013 Share Posted August 25, 2013 Terminators use them and it's a great upgrade. Honestly, I just chopped the Twin-Linked Bolters off of my Cataphractii hands and replaced them with the Volkites. If anything, you can use the Bolters on some Sergeants if allowed (depending on unit). Link to comment https://bolterandchainsword.com/topic/278905-volkite-chargers/#findComment-3434567 Share on other sites More sharing options...
klisof Posted August 28, 2013 Share Posted August 28, 2013 The chosen in the command squad can take chargers as a replacement for the bolters. With the tactical support squads, I see the squad with calivers providing long range fire support and holding a rear objective while the tactical squads advance to rid fire range. It's hvy 2 as well, not hvy 1 :) Link to comment https://bolterandchainsword.com/topic/278905-volkite-chargers/#findComment-3437472 Share on other sites More sharing options...
Emperor's Furor Posted August 28, 2013 Author Share Posted August 28, 2013 I've given my cataphractii 4 chargers, so I still have 5 left. I will probably have a command squad for my praetor whose counting as Numeon, so I could give them chargers to :) Link to comment https://bolterandchainsword.com/topic/278905-volkite-chargers/#findComment-3437912 Share on other sites More sharing options...
