Okay- something popped up the other day, can a lord get two daemon weapons? I think that it can't as it says a model "may replace ONE weapon with ONE of the following"
So I reckon it means that ya can only get one on a model, however my friend reckons that ya can swap say 2 weapons for 2 daemon weapons?
And also- do you choose which weapon to hit with and do all the rules of weapons stack?
For example if ya could have 2 daemon weapons- like the Black Mace and The Axe of Blind Fury would all his attacks have:
AP2
S +2
Fleshbane
Cursed
Blinded
AND get 2D6 attacks for them both being daemon weapons? :)
https://bolterandchainsword.com/topic/278927-daemon-weapons/
General consensus is that you can only swap out a single weapon for a single artifact, but without an actual FAQ ruling it can go either way. I lean towards not being able to do it though.
Even if you could take both, you still have to choose which to use in any given turn, so if you have both the axe and mace, you could only use one at a time. However, you would get an extra attack for having an additional weapon as neither are specialist weapons.
I would agree if my opponent wanted to use 2 Daemon Weapons, with 1/3 chance of getting a wound and WS1 good luck!<br /><br />"Replace one weapon with one of the following" in my opinion means that if you're taking 2 Daemon weapons - you do not have pistol and CCW on your lord any more, and Daemon Prince cannot take 2 Daemon Weapons because he had only 1 CCW.
okay- so, you say he can only use one at a time, does that then mean that he can get 2D6 attacks from having 2 daemon weapons?
in a similar vain to this does that mean that abbadon does not get say "shred" from his talon of horus when attacking with his daemon weapon?
