Cataphractii with Mauls?
Well unless you play against anything that has a lot of AP2 CC weapons I'd suggest taking powerfists, makes everything go squish msn-wink.gif I assume you're using the legion rules against the xenos scum?
Also I've put combi plas/melta on mine. Means you can deepstrike behind armour (with the correct rite of war)
Also means they are compatible with my 40k CSM's so I don't need two sets of termies :)
